Question about LG VX8100 Cellular Phone
Car kit is on and i can't turn it off. - LG VX8100 Cellular Phone
  • 2 more comments
  • ZeBallz Dec 30, 2007
    Can't turn off the car kit
  • archstud09 Jan 07, 2008
    Car kit has been turned on but I can't turn it off.
  • Anonymous Jan 08, 2008
    stuck on car kit
  • Anonymous Feb 02, 2008
    Car kit is on, can't get it off
I would rub a piece of metal where you plug the charger in on the bottom. A paper clip seems to work well. This will reset the phone and should be ok. It worked for me when my phone got wet and was stuck in car kit mode.
Good Luck
Posted on Mar 17, 2008
I would use a old dry toothbrush on the charger prongs works perfect everytime
Posted on Jan 16, 2009
I used a bobby pin and it worked just as well!!
Posted on Nov 09, 2008
Paper clip worked - awesome
Posted on Oct 30, 2008
The paperclip trick does work, but to be more specific, you want to play with the last 2 prongs on the right side with the outer screen facing up... It seems that what is causing the issue is that sometimes when you plug in the charger it causes those prongs to get a little bent and touch one another. When you adjust them, you break the contact and that's what fixes the issue. If you can't get it right away, keep trying, it will work! Good luck folks!!!
Posted on Sep 03, 2008
Paper clip worked for me
Posted on Aug 30, 2008
Posted on Jul 03, 2008
I didn't think that it was real, to use a paper clip but it worked! it's nice try it, if it doesn't work I'm sorry it it worked for me at this point thank you.
Posted on May 17, 2008
Paperclip trick aslo work for me, thanks!
Posted on Apr 30, 2008
The paper clip did the trick for me!
Posted on Apr 17, 2008
I have a LG VX 5200 but this problem seems to be on many phones. The solution I found is: I tried the other suggestions I found on this sight with negitive results. So I carefully took the back off the phone by removing the 5 small screws and pried the back off. I found a few grains of sand stuck in the contacts were the car plugin connects to the printed circuit board. I brushed them away and blew the phone out with compressed air. Put the phone back together and it worked. To me this was a very easy fix but for some it may be challenging. Don't break the phone when taking it apart. Good luck.
Posted on Feb 12, 2008
Just brought a HTC wildfire and I cant find bluetooth to turn it on .
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so HTC Wildfire S can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press howtoimage.aspx?id=106492, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. HTC Wildfire S will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. HTC Wildfire S then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to HTC Wildfire S, the Bluetooth connected icon howtoimage.aspx?id=106796 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Mar 28, 2012 | HTC Wildfire Cell Phone
How do u install it in your car
there is a users guide and maunals in the package,just follow instructions:
Please note this car-kit will not work in cars that use optical cabling. Check with your car dealer before ordering. Also, since this car-kit is installed by hard-wiring to the existing car stereo, professional installation is highly recommended.
Turn on the car engine and the phone connects wirelessly to the Parrot CK3100 Car Kit. The screen unit has easy-to-navigate menu options just like your phone, and your mobile phone book is wirelessly downloaded to the car kit. Calls can be dialed either through the screen, or by using voice-recognition speed dialing. According to your phone's model and firmware, most features are accessible from the hands free console, including one-touch redial, dual call, and auto-answer.
Feb 23, 2011 | Parrot Hands-Free Car Kit with LCD Display...
Lg vx8300 verizon says car kit display have no
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. and thats why you're not getting any sound. There is no specific setting to turn on or off 'car kit' mode you can use a paper clip or something and mess with the port a little bit to see if 'car kit' goes away or replace phone
Jun 23, 2010 | LG VX8300 Cellular Phone
The remote does not turn on the Delphi XM Xpress on car unit
This problem is caused due to the fact that xm has designed there radios to completely shut off all power with the unit therefore the unit once off will not be able to recieve information from the remote. This manufacturing defect was confirmed by the xm representative, they also explained that the company is currently planning to fix this issue on the new 2009 model xpress rc
Mar 30, 2009 | Delphi XpressRC XM Satellite Radio...
Cant connect my iphone to nokia ck-7w
not compatable, the nokia kit has very old software and will not work with Iphone, look at Parrot MKI car kits made for Iphone, very good.
Jan 16, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Car kit mode
ok take a paper clip, and lightly graze it inside the chargerport of ur phone, slowlymove it left and right, lightly rub it against the top half of the little piece inside the charger port, look at yr creen andwait for car kit to turn off. if ur phone turns off, dw. turn it backon adn dont rub the area u were rubbing wen it turned off.
once car kit turns off, it most likely will turn back on, repeat thisstep. eventually,it will go away forever.
it took about a day for the car kit to stay away completely for me.
trust me, i've been were u are. i tried everything and it never worked. then wen all hoped seem lost, at 11:30 at night, i found this and it worked beautiful.
also, u dont need to use a paper clip, anything metal will work. but paper clips the best because of there size.=]
Jul 01, 2008 | LG VX8300 Cellular Phone
Helpme turn off the Car Kit
Turn off your bluetooth, that should do it. It may be connecting to somthing else
Jan 23, 2008 | Cell Phones
Car kit mode???
The Car Kit message is usually caused by corrosion in your charging port. Yes, holding * may revive the phone, but your best bet is to get some contact cleaner and a toothbrush and clean out your charging port.
Sep 25, 2007 | LG VX8300 Cellular Phone
Car Kit Setting
get aluminum foil and insert it in the charger thingy and rub for a little bit, it worked for me
Jun 27, 2007 | LG VX8300 Cellular Phone
LG VX8100 Cellular Phone Logo
216 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
