Question about Toshiba Satellite A135 Notebook
Monitor problem my monitor looks like it is being attacked by a black blob of ink stretching from one side to the other. it is only at the top of the screen but am afraid it will spread farther down. what is this and can it be fixed? thankyou
  • Terry12 Jan 03, 2008
    HI, My notebook monitor is suddenly displaying a straight line from one end to other end. the line is just below the center of the screen. everything is working fine except the line. Is this some issue related to the power supply to the adapter ? Also what can be done to fix this. The laptop is new and hardly used. I do not have any other monitor to test this. Thanks.
    Sergeant:
  • 263 Answers
Looks like your screen is damage can you do a test plug a external monitor to the back of your computer on the video conector if the image is ok that means your video converter is damage or your screen i hope that will help you
Posted on Dec 30, 2007
I run on Windows XP, pack3 and I use a CRT ViewSonic EF70 ... 17 inches The screen is not filled completely with the image from Microsoft Internet Explorer, nor with Outlook Express .... there is about 3...
two things you can do, first right click on your windows screen and look for "settings" this will open a dialog box where you can set the screen resolution. Set it lower and see if your screen is now filled. if that doesn't work go into the monitor setup (buttons on the bottom or side of the monitor) and try to set the verticle and horizontal size, since its only 3/4 of an inch you should be able to stretch the screen to fill up the space.
Mar 11, 2011 | ViewSonic E70f 17" CRT Monitor
3 inches of black on both sides of my monitor
I have seen this when using HDMI cables from the computer side.. The TV has a resolution that is not always full screen with TV shows. There is a setting that allows you to "zoom". My TV has 4 settings: normal, stretch and crop, stretch left and right, stretch and pinch (shrug).
Jul 07, 2009 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
Giant blobs of ink on every photo...
If you aren't currently, use the cartridge that the printer's manual says is for photos. Photo paper requires a different kind of ink.
Jun 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Ink blobs on paper
It could be both. Leaky ink can be a problem and that probly is the problem. But, make sure your rollers are clean and cheak that your ink is not leaking. I hope this has helped you.
DigicalJAI
May 19, 2009 | HP Photosmart C4280 Aio Printer
My screen is stretched with a 1 and ahalf inch black space on the top and bottom
Most LCD monitors have a couple of control buttons at the top or on the side. Inside the menu, there should be an option called "Auto Adjust" which senses the input signal and resolution, and then shifts the monitor to match it. Have you tried to auto-adjust the screen? There may even be a button called "Auto" on the monitor.
May 13, 2009 | Computers & Internet
How to open a ACER AL1713 monitor
Hi - there are more hidden screws so you need to undo those:
  1. Where the stand joins on the back, there are two plastic bits either side of the pivot. They don't look as if they come off but if you squeeze them (squeeze top and bottom) then they unclip.
  2. Remove the 4 metal screws you have just revealed (2 each side)
  3. Remove the 4 larger metal screws holding the stand to the monitor
  4. Remove 1 metal screw that you have just revealed which was hidden by the metal plate on the stand holder.
  5. Use a straight-bladed screwdriver to create a gap at the bottom of the monitor between the silver front / black back of the case.
  6. Open this up all around, and remove the silver front - undo the multi-cable connector which connects to the operating buttons and put the silver part to one side
  7. Lever out the monitor chassis.
  8. Put the LCD face down on a table but make sure there is nothing underneath it (I have two black blobs where mine sat on a bump in the table!)
  9. Then open up the cage with the electronics in it, by undoing 2 screws and sliding the cage off.
  10. Remove the four screws holding on the power board (the big one with a mains connector, disconnect any connectors, and then remove the board.
If your monitor is not working (even if the power light is dead), check for swollen electrolytic capacitors (tall things with an x at the top, made of metal with plastic around them). If you have swollen ones, that's probably why the monitor doesn't work. Replace them (make sure the + and - sides are in the correct places when you replace) and hopefully your monitor should work.
If it still doesn't work, look for any heat damage and poor soldering.
Apr 10, 2009 | Acer AL1713 17" LCD Monitor
Ink blobs and smears on paper
Call lexmark and they are going to send me a new printer since it is still under warranty.
Jan 15, 2009 | Lexmark T632n Laser Printer
Ink build up under cartridge
if u look at the back of the unit there is a back door which u can take out .
or u can open the front access door [ from where u insert the cartridge ] , in case u r not able to clean it from there .
u might need to get the unit serviced ,for that either contact HP customer care at 1800 474 6836 or on-site Repair Center at 800-633-3600.
Thanks
May 22, 2008 | HP Officejet 5610 All-In-One InkJet...
Toshiba Satellite A135 Notebook Logo
101 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
