Home | Apple | iPhone Smartphone | Sometimes my Iphone wil...
Apple iPhone Smartphone
Problem for Apple iPhone Smartphone
Sometimes my Iphone will not charge when i connect
By lskrauskopf on Oct 21, 2009
Sometimes my Iphone will not charge when i connect it to the wall charger. I just bought my iphone a couple of months ago.
Solution #1
posted on Nov 08, 2009
Somewhat Helpful)
keatonhokins
Rank: Apprentice
Rating: 75%, 1 votes
If your iPhone is not charging when you plug it into a wall charger or into you computer's usb port, this is a usb connectivity issue and the connection just needs to be reset. All that needs to be done is plug the iPhone's cable into the phone but don't plug into the computer yet. Hold the phone's select button (the round button with the square) down for about 30 seconds or until the apple appears on the screen. your phone will reload and reset the connection and the computer should recognize the device. Allow the phone to charge for at least 30 minutes before unplugging.
Was this helpful?
Yes
No
Solution #2
posted on Oct 21, 2009
Not Rated)
jonniewalker
Rank: Guru
Rating: 88%, 588 votes
The easiest way to charge an iPhone is to plug it into the USB port of a computer or some wall chargers may not supply exactly +5v which the iphone requires. because the iPhone doesn't charge like other normal USB devices. Just by supplying 5 volts to the USB cable of the iPhone will not charge it. That's why most wall chargers will not work with the iPhone.
Was this helpful?
Yes
No
Popular Solutions for Apple iPhone Smartphone
Questions and Unsolved Problems for Apple iPhone Smartphone
Do you recommend Apple iPhone Smartphone?
Answer
Answer
My iPhone screen has gone blank and has stayed blank. I can here if a call or TM comes through but... (More)
Answer
after I reset to factory settings, The phone restarted and slide to unlock does not work. This is a... (More)
Answer
my i phone home button will not function when on charge, works fine when no connected
Answer
how can i send a sms message on my iphone to all my contacts (350) at the same time... without... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple iPhone Smartphone:
Top PDA Experts
Rank: Guru Guru
Solutions: 551
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
