Question about Canon EOS Elan 7ne 35mm SLR Camera
Error 01 coming up on the screen, will not take a photo. Really need it to work.... please help.
  • Anonymous Mar 20, 2008
    using my 20D EF 100-300 error o1, in the manual book says its about conecting sensors between the lens & the cam body... both are clean ports, so what 2 do plz??
Clean the contacts between the lens and the camera.
Posted on Jan 17, 2008
What is error 99 in canon eos 20d
It's a frustrating catch all error and needs service.The camera may have any one of numerous issues or lens issues. If you have more than one lens, see if the error occurs with both lenses on. If not then it's a lens error. A camera repair facility can plug unit the camera and download a more accurate troubleshooting code. Royal Camera Service in Hanover Park, IL is good source for this problem. The replaced the shutter on my 20D when I got the error 99 code.
Feb 06, 2013 | Canon EOS-20D Digital Camera
My Canon EOS Rebel XS only takes pictures indoors (ERR. 01)
You didn't say which shooting mode you're using, but I'd bet you're in Manual mode and have dialed in a completely wrong aperture/shutter speed combination for bright lighting conditions. For example, 1/60th of a second and f2.8 in bright sunlight would be "burning out" your image, so the camera may be giving you an error message. Try using AUTO or PROG setting and see if the problem persists. If it does, try a different lens. You may have an incompatible mount, or one of the contacts may be damaged. If all else fails, try your lens on another Canon camera.
May 14, 2017 | Canon EOS Rebel XS 35mm SLR Camera
Canon eos 20d error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 20d service manual link:
it will help you to save a lot of money
Hope it helps, Thanks
Aug 07, 2011 | Canon EOS-20D Digital Camera
When i try to take continuous shots, my camera gives an error. it says my camera and lens communication is faulty. error 01. clean the lens contacts. what is the lens contacts?
This is a basic fix, but have you removed the lens from the camera body and reattached it all? Check all of the connections while you're in there. Hope this helps =]
Mar 03, 2011 | Canon EOS-20D Digital Camera
Will a SIGMA 70-300 f4 DL MACRO LENS fit on a CANON EOS 20D?
Assuming you get the lens with a Canon mount, yes. Sigma makes lenses to fit a variety of makes, but each one has a different mount. A lens intended for a Nikon, for example, will not fit a Canon.
Dec 08, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Error 01
Error 01 is about the communication of the LENS with the camera. Please try to re-attach it and make sure it is correctly fitted. Also you can remove the lens, start cleaning the contacts, put it back in place again and then test.
Oct 24, 2010 | Canon EOS 30D 8.2MP Digital SLR Camera...
I got error 099, before I was getting error 05. and the flash dos not open canon EOS 20D
I also get the error 99 message and cannot take any photos... I have been able to solve this problem by taking out the batterys and wiping down the connectors on both the batterys and the connecters in the motordrive with a lens cloth. keep the lens cloth on hand when shooting. It may be that either oils, or dirt has gotten onto the connectors. I hope this helps.
Mar 23, 2010 | Canon EOS-20D Body only Digital Camera
I have a canon ds6031 eos 10d. When I turn the camera on the view screen does not show what your pointing at. Is this normal?
Yes, it is normal. This is a reasonably old DSLR, and it's designed for you to look through the viewfinder (it's more accurate anyway as it's looking through the lens). You'll find if you keep one hand under the lens and one hand on the shutter, it'll feel quite comfortable to look through the viewfinder.
You can still view photos you've taken after you've taken them though.
Aug 31, 2009 | Canon EOS 10D 35mm SLR Camera
Hi all, I wonder if you can supply some advice regarding a Sigma17-35mm lens I purchased earlier in the year. Basically if I use the automatic or 'P' setting on my Canon EOS 30D camera the image is over...
Try your EOS in AV (aprature value) mode. You should be able to adjust your aperature value in 1/3 or 1/2 steps dependind how you have your Custom Functions set in your camera's menu. Possibly the lens you purchased is for an EOS 35mm. If you use a 35mm lens on your eos there are some calculations you must use. When using a 35mm lens on the EOS 20D, 30D, 40D and 50D bodies, you must first calculate your focal leingth by 1.6 times. With this, your exposure changes as well.
The only EOS Digital SLR bodies that use a 35mm x 24mm CMOS sensor are the 1D and 5D. My wife uses a Tamron 18-200mm f3.5-5.6 lens on her 20D and loves it.
If this makes no difference, you may have a defective lens.
Nov 29, 2008 | Sigma Cameras
Getting scratching in the photos
There may be 2 chances
1. ur lens might have got those scratches. U might to change the lens in that case
2. Due to low light the scratch effect is appearing. U might need to change the setting accordingly
If not, you may need to contact the canon service
Dec 29, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Canon EOS Elan 7ne 35mm SLR Camera Logo
198 people viewed this question
Top Canon Photography Experts
old marine
old marine
Are you a Canon Photography Expert? Answer questions, earn points and help others
