Samsung RS253BABB. Where is the water pump??? I press the switch for the water dispenser and I can hear the pump running but no water comes out. The ice maker works so its getting water to the unit through the filter but thats it.
You
have two points where you can check the dispenser water. At the rear where the
water supply comes in is the water inlet valve. If you disconnect the dispenser
water line and then see if the water comes out when you try the dispenser. You
should hear the valve work when you try the dispenser. If you don’t hear it
there is a dispenser actuator switch problem.If you do hear it but water
doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of
the freezer door and try again.If it's normal here it may be frozen in the
door. If this is the case open the door till it thaws. A blanket over the
opening will prevent thawing of all the food.
Was this helpful?
Yes
No
Popular Solutions for Samsung SRS20DTD Side by Side
My samsung side by side fridge/freezer has a flashing light on the fridge temp control 3rd light...
(More)
My samsung side by side fridge/freezer has a flashing light on the fridge temp control 3rd light down but the freezer has stopped working. The lights still on in the fridge but I can't control the temp on any off it. The last temp I had the fridge on was minimal as it hardly had anything in it so it's stuck on that setting if working at all. The serial number is Samsung Interlect DA68-11152F
Samsung SRS20DTD display error item details for error item 1 IM SENSOR probl of ice makr sensor. how...
(More)
Samsung SRS20DTD display error item details for error item 1 IM SENSOR probl of ice makr sensor. how to replace.
I am having a similar situation with my Brada M-183 alert light and resulting defrosting. I have...
(More)
I am having a similar situation with my Brada M-183 alert light and resulting defrosting. I have defrosoted, left sit and plugged in to no avail. Please help!
