Mitsubishi WS73713 - Now working - Timer light flashing.
The green timer light near the On-Off button is flashing. The TV is not working. I have reset the TV and disconnected power.
After reset the green light starts and keeps flashing. Same after power removed and restored.
Any ideas?
Any ideas?
  • 1 more comment
  • cndylu May 31, 2008
    timer light flashing, wont go out, when i push reset it doesnt help, tv wont come on
  • Anonymous Aug 16, 2008
    I just encountered the same problem yesterday--with the "flashing green light/no power-on" situation in my Mitsubishi WS73713 RPTV.
    Apparently it is not an uncommon occurrence--and often invloves the low voltage power supply...the DM module has often been referred to.
    Does anyone have a diagram/fix that you wil share with me?
    Thanks
  • dtrz May 14, 2009
    I have a mitsubisi WD-52525 and the green timer light is keeps flashing and the Tv will not turn on
  • 33 Answers
Hold menu button for 8 sec and then unplug for 1 minute. then when you plug it back in it will work after 1 minute
Posted on Jan 24, 2009
I paid Gupka at "Fixya" $24.00 to tell me I had a power problem! Ok, SHAME ON ME. Then I called Mitsubishi Cust Svc @ 1-800-332-2119 as suggested which is in THE PHILLIPINES and "Bob" said he would escalate and someone would call me IN 2 DAYS. It's called THE RUNAROUND. HP does it, ATT does it, eBay does it, etc.....A complete spit in your face as customers by Corporate pieces of garbage from off shore peons.
Posted on May 16, 2011
The capacitors on the dm board are probably bad. I called mitsubishi and they agreed to pay for the part even though my tv is four years old. MITSUBISHI cust # is 1-800-332-2119
Posted on Jan 24, 2008
Dm module is bad call 1-800-332-2119
2 Suggested Answers
SOURCE: Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Posted on Jul 01, 2009
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Nov 09, 2007 | Televison & Video
Televison & Video Logo
1,879 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
