Question about One For All URC-4330 Remote Control
Remote i have a sylvania tv/vcr combo that the codes supplied do not seem to be working. i tried the search featured which allowed me to use the channel up button until i press another button then i have to do the search codes again. can someone help me please
Try 1124 1243 1145
Posted on Jan 07, 2008
What is the onn universal code for sylvania model 6719DFDF
0392. Check this code. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 10, 2015 | Sylvania Televison & Video
Looking for code for my sylvania tv for my one for all access 4 u remote
Hello
Universal remote codes for Sylvania TV with One for all URC - 3300 remote control are:
0054, 0030, 0171
Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
code in the following boxes
OK.
Jul 13, 2011 | One For All URC-3300 Remote Control
I need the remote contol code for a sylvania 6313cb 13in. tv/vcr combo
Hello
Universal remote code for Sylvania TV/VCR Combo is:
0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
May 31, 2011 | Sylvania 6313CB 13 in. TV/VCR Combo
Can't program my remote to my Sylvania tv! I've tried every code they had for it. It's a 13 inch tv/dvd combo and its a comcast remote. Please help!
Although you didn't explain what brand of universal remote this was for, all universe remotes have a code search option for this situation. Check the manual for your specific remote control for more details.
Often manufacturers of multiple brands will use the same infrared (IR) codes for all of their brands. For example, Panasonic and Quasar share the same codes as their parent company is Matsushita Industries. In your case Funai is the parent company of Sylvania and the parent company of Magnavox so you might want to try the Magnavox codes before doing a code search. As Funai also manufactures televisions for Toshiba and Sharp, so try those codes as well.
Apr 23, 2011 | Sylvania 6513DE 13 in. TV/DVD Combo
Im looking for codes for a sylvania tv
The codes to try for Sylvania TVs are 0054 0030 0171.
The manual and codes are available from the One For All support site: http://www.oneforall-na.com/remote.php?type=URC%203021 . The link for codes is at the bottom right of the page.
However, most remotes are limited to codes for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, then you may need to get a newer remote.
I hope this helps.
Feb 25, 2011 | One For All URC-3021 Remote Control
Sylvania srcd227 remote code/tv/vcr/dvd combo
hi! i have here a couple of codes for your tv! just try them 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465,1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!
Mar 05, 2010 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Directv remote (RC64) problem with sylvania 6319ce tv/vcr combo
I installed systems for Directv, and whenever i went into a home that had a combo tv / vcr, i could never get a set to program properly. At the most on some sets the remote would turn the tv set on and off, but others functions were non responsive.
Nov 06, 2009 | Sylvania 6319CE 19 in. TV/VCR Combo
Need 4 digit code forsylvania tv dvd combo model ld195sl8a
Unfortunately, your remote control predates TV/DVD combos and as such the manual does not list a code for a Sylvania TV/DVD combos.
To make this control work with a TV/VCR combo, one would enter 0054 for the TV controls and 0081 for the VCR controls. May I suggest you try the following codes for the TV: 0054, 0030, 0096, 0020, 0381. If these codes do not work, try running through the auto-code search.
The manual for the URC-4330 does not list any Sylvania DVD codes at all, so I recommend running through the auto-code search. Here are the steps:
  1. On the remote control, press DVD once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the DVD and slowly alternate between pressing POWER and DVD. Stop when the DVD turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 15, 2009 | One For All URC-4330 Remote Control
Trying to get my directv remote to control this TV but none of the Sylvania codes recommended work any ideas
slide the mode switch to tv, hold down mute and select until the light blinks enter "9-9-1-------1" when the lights finish blinking start pushing push the channel up button. this is a code search. It will transmit every code it knows one at a time. when the tv turns off you've found a code that works. turn it back on, try the volume and see if it works correctly. when finished press select.
most tv/dvd and/or vcr combos won't work with tv codes.
Directv has posted many new codes on their website for combo tv's Go to [ www.directv.com/remote ]to look up the latest codes read the programming section for the remote as there are many customizable features on the remote that most people aren't aware of. good luck
Sep 23, 2009 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
One For All URC-4330 Remote Control Logo
24 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
