Home | Canon | EOS 400D / Rebel XTi Digital Camera with 17-... | Camera won't shoot whe...
Canon EOS 400D / Rebel XTi Digital Camera with 17-85mm Lens
Problem for Canon EOS 400D / Rebel XTi Digital Camera with 17-85mm...
Camera won't shoot when shutter button is pressed
By ronaldpruitt on Oct 21, 2009
I have a tried everything I know but nothing has helped. When I try to take a photograph, press the shutter release button, a 9 with a green flashing light shows up in the bottom of the view finder and the camera will not trip the shutter. I've tried resetting the camera's setting, I replaced the battery, I've turned the camera on and off several times. Can anyone explain what this is and why the camera won't work, and possible what caused this problem. The self timer is not on, I checked that also. It's on the single shot mode. and I've tried all the possible settings on the top of the camera with no change.
Same Problem
Nov 07, 2009
-   I have this same Problem, with the same camera.-   misskierstin
Solution #1
posted on Oct 21, 2009
Not Rated)
BillB-SA
Rank: Guru  Canon Cameras & Camcorders  Expert
Rating: 85%, 339 votes
It's nearly impossible to troubleshoot the camera without seeing it, but your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Was this helpful?
Yes
No
Popular Solutions for Canon EOS 400D / Rebel XTi
Questions and Unsolved Problems for Canon EOS 400D / Rebel XTi
Do you recommend Canon EOS 400D / Rebel XTi Digital Camera with 17-85mm Lens?
Answer
Answer
the flash pops up but doesnt work. than gives me a busy signal than gives me the 99 warning. it was... (More)
Answer
if the picture is taken vertically in EOS 400D SLR, there will be a black shade appearing in right... (More)
Answer
I have the same problem but I get this Err 99 message. It tells me to turn off the camera or... (More)
Answer
error message "the built-in flash's auto pop-up was obstructed. turn the power switch to off... (More)
Answer
I'm getting an error msg sayign shooting is not possible and to utn power switch to on and off again... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon EOS 400D / Rebel XTi...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
