Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer will not fill with water
My washer (Whirlpool Ultra Care II) will not hold water when the rinse cycle starts. It's intermittent when it does this. I've tried going to the end of the whole cycle to see if I can reset it but nothing works. Any ideas would be helpful. Thanks.
    President:
  • 1,314 Answers
See if your drain hose is too far down in the drain if it is will pull water out soon as it fills also drain hose needs to loop almost as high as the top of the tub if you pull the hose up quick you can hear the suction break
Posted on Dec 30, 2007
Is your drain hose lower than the top of the cabinet?? The curved part of the drain hose needs to be slightly higher than the top of the cabinet. Also, the drain hose must have an air gap around it where it goes into the house drain. It sounds to me like your washer is syphoning water out through the drain hose as it is trying to fill. Hope this helps..............
Cold water won't come on and no rinse cycle
Remove cold water fill hose from the hydrant and washer.
Check if the screens are filled with debris.
Check screen on watervalve of washer.
If clean the cold water valve, the timer or water selector switch.may be bad.
Jan 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer will not stop at end of cycle
Turn off extra rinse switch or pull wire going to it. If water is slow the water valve may have a restriction in it. Remove hoses and check for blockage in the hose screens.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Cold Water runs constantly even if the washer is off
you will need to replace fill valve where hoses connect probably has sand in valve especially if screens have been removed remove screws in rear of console lift and roll console back disconnect wire to lid switch remove clips om right and left rear corners cabinet lifts off disconnect hoses and wires 1 screw usually holds valve in postion
May 01, 2008 | Whirlpool Ultimate Care II GSW9650LW Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
49 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
