Tv remote RE Bell PVR system
Hi
I have a bell satellite PVR system. The techs that have set up this unit, has programmed the remote unit that came with the PVR to work with the Sony mode (KDF42WE655). Recently I’ve encounter a problem and I am not sure how to correct. The problem is I always have a video label 7 on my TV screen and I cant seem to remove I have tried rebooting the PVR unit, also tried to reprogram the remote control. Can you help me to remove this video label off the TV screen?
Thanks in advance …
SOURCE: lost directions for universal remote control
Found the codes after an aggravating search, lost the instructions myself but finally found a copy:
Express view sat. codes: 0654, 0647, 0655, 0628
Star choice sat. codes: 0640, 0645, 0627
Sanyo TV codes: 0049, 0097, 0110, 0004, 0268, 0012, 0108, 0180
Nexxtech should post these - you get what you pay for I guess.
Posted on Feb 08, 2008
SOURCE: Universal remote code
http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/remotehome.shtml
Code 720# for my 26" insignia tv on me bell remote 3.2 IR - 137181 and it worked for me. Click on link choose the type of remote you have.
Good luck
Lapete
Posted on Mar 23, 2008
colin12
sent to me by nextech....
Save Code list for future reference. Refer to the setup procedure below and look up the 4 digit code for your brand of TV, VCR, etc., from the list below.
1519001B, 1519002B, 1519003B, 1519006, 1519007 CL
Refer to the Owner’s Manual for your remote for more information.
Direct Code Entry
1.
Press and hold the
SETUP button until the
red indicator stays on,
then release the SETUP
button.
2.
Press and release
the desired Mode button
(TV, VCR, etc.). The red
indicator blinks, then stays
lit.
3. Enter the 4 digit code from
the code tables. Note: after
a valid code entry, the red
indicator turns off. For
an invalid code, the red
indicator flashes.
4. With your device on,
press CHANNEL UP. If
the device responds, no
further programming is
required. Note: If some
buttons do not operate
your device, try one of
the other codes for your
brand.
Note, when all codes have
been searched the red
indicator flashes rapidly for
3 seconds.
Code Search
If after trying “Direct Code
Entry” your device does not
respond, or if your brand is
not listed, try doing a search
of the code library for your
code by following the steps
to the right.
1. Manually turn on the
device (TV, VCR, etc.) to
be controlled.
2. Press and hold the
button.
3. Press and release the
desired Mode button
indicator blinks once, then
stays on.
4. Press the CHANNEL UP
button repeatedly (up to
300 times) until the device
to be controlled changes
channel. The red indicator
blinks, then stays lit.
5. Press and release MUTE
to install the code. The
indicator light goes off.
Most users will want to
store VCR codes under the
VCR button, Cable codes
under CBL, etc. If you want
to store a VCR code under
CBL, etc., first follow the
procedure for Direct Code
Entry and press CBL in step
2 of Direct Code Entry, then
enter ANY VCR code in
step 3 of Direct Code Entry.
Then follow the steps above
for Code Search.
Direct Code Entry
1.
Press and hold the
button.
2.
Press and release
lit.
indicator flashes.
brand.
3 seconds.
Code Search
to the right.
be controlled.
button.
desired Mode button
stays on.
for Code Search.
answer found at support@orbyxelectronics.com
Posted on Jan 15, 2009
jan mczeal
  • 632 Answers
SOURCE: Sony (KDF42WE655). Always have a video 7 label on the screen
Try these:
  1. Press MENU on the remote control
  2. Select Settings
  3. Highlight Setup
  4. Select Label Video Inputs
  5. Select Video 7
  6. Select None if available or
  7. Leave the label blank
Posted on Aug 23, 2009
vljenterp81
  • 86 Answers
SOURCE: Remote Control Programming
it is so good to hear from you friend. the replacement remote that you need is on newremotecontrol.com. the number that you are looking for is 148058621. this remote cost 24.95. thank you for writing and please rate my solution.
Posted on Nov 18, 2009
I have RCA RLDED5099 Tv, but can't program it to work with my Bell satellite remote so I can then work My JVC THA35 home theatre..
Bell Satellite remote codes for RCA TVs: : 001,005,006,008,012,014,015,018,023,
025,035,066,077,085,121,124,131,133,135,
144,148,150,151,152,155,160,167,190,194,
222,223,225,227,232,236,245,248,268,269,
282,288,289,317,431,486, 492
Instructions for when the code for your device is not listed. Use this procedure to scan the remote control’s memory for the device code
1. Turn the device on (TV).
2. Press and hold the mode button until all the other mode buttons light up, and then let go of the button. The mode button flashes.
3. Press POWER.
4. Press the UP or DOWN ARROW repeatedly until the device turns off.
5. Press POUND (#).
6 .Turn the device back on and try some other buttons to make sure they work
7. If necessary, repeat this procedure
How to program my Bell Satellite TV remote control
Apr 09, 2015 | RCA Televison & Video
I have a 27 inch symphonic crt tv. i have a bell satellite reciever hooked up to it with the renote programmed for the tv. i accidentally hit the mute button and now there is a 2 on each corner of the tv...
hi there, plugging and unplugging won't work that way. Pls try This:
1. look for the Program menu of your bell satellite unit
2. under menu you will see the settings there and try to reconfigure it or reset the current program.
3. scan for available channels and save it. i hope this will help you a little. Thank You.
Feb 07, 2011 | Televison & Video
We just got a new Dish HD/DVR Receiver and need the remote code for the Bose remote control to operate it.
Here is what I did for my Bose Solo Tv to work on the Bell 9242 receiver.( see page 17 of Bell 9242 guide) 1. Hold down the aux button until all lights flash. 2. Press 2 to ensure Aux is set to audio. 3.Enter code 761 and press the pound (#) button. Now to have the satellite remote default volume to Bose Solo do the following. 1.Press and hold AUX 2.press # pound 3. Press the + side of volume 4. Press 0 5. Press pound ( AUX button will flash 3 times) 6. Press SAT mode 7. Test the volume on Bose Solo. (see page 22 of Bell 9242 guide)
Jul 05, 2010 | Bose 3 2 1 GSX System
Volume control doesn't work with my bell remote,
Guest
I have provided instructions on how you can program your remote to your TV. The first link is the instructions to program. The second has the available codes for the TV brands.
Program remote:http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
I hope this helps.
Ray Calo
DISH Network
May 14, 2010 | DISH Network IR Remote Control
Program bell remote to emerson tv What codes do I use to program my bell satellite remote to be able to tun off/on tv and to use the volume from one remote
Hi try this
Emerson 526, 534, 536, 541, 573, 590,
627, 636, 642, 648, 652, 654,
655, 657, 658, 659, 660, 661,
662, 665, 666, 667, 669, 670,
677, 679, 682, 692, 696, 699,
720
http://www.bell.ca/web/tv/en/all_regions/pdfs/deviceCodes.pdf
good luck please rate
Dec 18, 2009 | Bell Televison & Video
Cannot program tv using bell satellite remote
Turn your TV on.
Press and hold the TV mode button until all the other mode buttons light up.
Press the blank POWER button. (If your remote only has one POWER button, press that one)
Press the UP ARROW button repeatedly until your TV turns off.
Press the POUND (#) button to confirm.
Cheers
Feb 01, 2009 | Hitachi 50FX30B 50" Rear Projection...
Good luck
Lapete
Feb 09, 2008 | Televison & Video
Remote code for Sony Homethetre on LG Remote
LG 32 LX2R TV REMOTE CODE TO WORK A SONY VTX-D8 U
Dec 30, 2007 | Televison & Video
Televison & Video Logo
198 people viewed this question
Top Televison & Video Experts
