Here's the configuration for that board. If your trying to overclock, you'll want to go with a higher setting.
CPUChiosei HT Voltace 11.20 VI Allows you to set the pocessorhipset HyperTranspoit voltage. Configuration options: [1 .20V] [1 .25VJ 11 .30V] [1 .35VJ [+1 .40V1 [+1 .45V] [+1 50V] Chtoset Core Vo#aae f1.40V1 Allows you to set the dlipset core voltage. Configuration options: [1 .40V1 [1 .50V] [1 .60V] Ctitpset Slan&w Core Vo?taoe 11.40 VI Allows you to set the diipset standby coe voltage. Configuration options: [1 .40V] [1 .6OVJ CIhVsef Fi-E Voitaae 11.50 VI Allows you to set the dlipset PCI Express voltage. Configuration options: [1 .50V1 [1 .55V1 [1 .60V] [1 .65V] [1 .70V1 CPU Vcore Offset Voltage fDisabdJ Allows you to csable or set the processo vCore offset voltage. Configuration options: [Disabled] [Offset lOO.OnIV] ASUS M2N-SU Deluxe
I am having problems with my Altec Lansing ADA885 speakers. They won't play although the sound is...
(More)
I am having problems with my Altec Lansing ADA885 speakers. They won't play although the sound is fine and the sound comes through headsets or even the speakers to my lap top.
need location of power sw wire and reset swwire on old ms 65-77 v2.1 mb using new mid atx case with...
(More)
need location of power sw wire and reset swwire on old ms 65-77 v2.1 mb using new mid atx case with 4 fans +pw supply fan. Will stay on only if i plug the mid pw connection to afan if i take off l.e.d.s lite up all fans will run then turn off after 7seconds . i also sence a burnt oder i think maybe i have a weak pw supply.
Windows don't start complitly , and hang in black screen just before welcome screen , but when i off...
(More)
Windows don't start complitly , and hang in black screen just before welcome screen , but when i off usb controller from bios setup , windows would start normaly , or when system hang in black screen if i put my printer usb cable in any usb port , windows will boot complitly!!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
