Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Not draining had water pooling at bottom of dishwasher. i've taken apart as much as i know how to but can't figure out how to get the last piece out - where the little wheel is located i guess used to flow water? lines look clean
    President:
  • 1,314 Answers
The drain pump is separate from the was motor and is accesed from underneath the dishwasher that help wash moter is one piece and is replaced as a whole unit and the drain hose comes from the factory making a loop up side the tub a lot of installers cut the ties holding the loop to get more drain line if loop is removed will loose its prime and stop draining or drain some times and not others when you first start the dish washers it drains then fills so you should hear the drain pump rum if something isnt jamming it
Posted on Dec 30, 2007
Water drains back into dishwasher from sink or disposal
You've got a broken piece of glass or something holding the drain valve open.
Solenoid operates the valve to drain water from dishwasher into drain line.
When power shuts off to solenoid...valve closes.
If valve is blocked by a piece of glass or toothpick or a sliver of bone...it can't close and draining water from disposal or sink can back flow into dishwasher.
I had a piece of glass caught in mine.
Hope this helps...
Jul 23, 2011 | GE Dishwashers
Dishwasher won't drain. runs through normal cycles, and then just stops still full of water on the bottom. I have taken it apart and can't see any obstructions.
is there a clog in the hose somewhere because when ours clogged it would not drain it just kept circulating water all over the clean dishes and it was gross
Jan 03, 2011 | Frigidaire 24 in. FDB635RF Built-in...
My dishwasher won't drain completely in the last cycle so in other words water remains in the bottom of the washer. Don't know how to take it apart and clean out.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 11, 2010 | Dishwashers
Water staying in the bottom of the dishwasher.
WEll, there always needs to be some water remaining, but, you may have a blocked drain system, this means hoses, connections, screens. Needs to be taken apart and inspected to find.
Sep 09, 2010 | Kenmore Dishwashers
Dish-washer
The problem is most likely that the pump empeller had been damage by pieces from a broken dish or a small piece of siverware. The only way to fix this is to take the dishwasher apart and replace the empeller. If you choose to do this yourself, you should go to the manufactures web site to see if you can download instructions on how.
Jul 14, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher will not drain completely
dishwasher will not drain.kenmore model.
I have taken it apart can not figure our how to take out last plastic part a bowl shaped black plastic.
Mar 22, 2009 | Jenn-Air 24 in. JDB1250 Built-in...
Water pooling up in bottom of dishwasher
is there any way to run the cycle from the beginning and listen to hear if the machine is draining at all when the cycle starts do you hear the water spraying on the inside ? if not then you have several different possibilities....clogged drain line, pump impeller broken(sounds like running but no action), water just flowing back to washer the last one's an easy fix just loop the excess drain hose up like a reverse "p" trap on a kitchen sink drain this keeps the water from flowing back to the machine
Dec 15, 2008 | Whirlpool Dishwashers
My Kenmore Elite UtraWash Dishwasher won't drain completely. We have checked the hoses (water supply and drain connected to the disposal) - both are free of obstructions. We have taken the whole thing...
I have the same problem. The part you're talking about can be released from under the dishwasher to clean it. www.searspartsdirect.com has useful diagrams. I cleaned everything but still have the problem which is caused either by the "check balls", the "check valve" or the "pressure check" thing. I still have to figure it out. A good way to know if the system is obstructed is to press the drain button when there is some water left in the bottom.
Dec 01, 2008 | Dishwashers
Dishwasher did not drain all the water
Your sink drain is clogged and the back pressure is not allowing the dishwasher to drain competely. Do not use a liquide drain cleaner, it will damage your disposal. take apart p-trap hopefully the clog is there, otherwise the line will need to be snaked.
Sep 22, 2007 | Roper 24 in. RUD4000M Built-in Dishwasher
Standing water in the bottom
try starting any program - all start with drain. if it doesnt drain, suspect a foreign object in the drain pump
Mar 29, 2007 | Kenmore 24 in. 15074 Built-in Dishwasher
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
114 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
