Question about Toshiba Tecra M7 Tablet PC
Toshiba M4 Graphics problems
I am getting red screen at startup and as my desktop loads. many logos, pics, etc also have red tinting. I suspect graphic card is going out? It it Nvidia GeForce. Is there any type of tool to check the performance of the card and/or any other suggestions as to what the problem may be?
Thanks in advance.
  • Anonymous Apr 08, 2008
    Same problem here. You can correct in color setting under NVIDIA control panel. However problem seems to get worse over time (now my M4 crashes).
  • 361 Answers
No. i think your monitor is old. some time we get voilatie or red screen .some time it take short or long time. and some time screen moving. main cause is lose joint part in monitor it can be fixeb by soilding every parts by expert.for conform u change other monitor.then u can get result . thanks
Posted on Jun 13, 2009
I installed windows xp on my toshiba tecra m4. How stylus pen works?
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen.
In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
Hope it helps! Good Luck!
Apr 23, 2011 | Toshiba Tecra M4-S435 Tablet PC
I have a screen problem. My Toshiba Tecra M4 has color imbalance because some black or blue colors become red. My laptop technician said there is a problem with the flex cable, but as I researched on the...
Toshiba is famous for overheating problems, blow out your cooling fan with canned air. Also another fairly common issue with the M4 is memory module seating, basically the memory modules/sticks werent put in properly by the factory...i know..go figure. Remove the memory panel from the back of the unit and remove the memory stick/s. Should be 2 of them, be gentle, and then just simply reinstall them back where they were making sure they are seated in the slots firmly, then replace the memory cover and fire it back up. This worked on 4 or 5 ive repaired with similar issues. Hope this helps you as well.
Nov 08, 2017 | Toshiba Tecra M4 Tablet PC
I just bought new lcd display for my Toshiba Satellite R10 Tablet. The inverter is fine, checked the cables and reconnected. But the screen alternately flashes solid white, red, green and blue on the...
you need to download the proper drivers for the Graphics Card Right click your desktop go to settings go advanced Go to the intel(R) tab and hit Graphics Properties thin pick' either Dual Display Clone or Extended Desktop and Click Apply.
Wierdly the Monitor 2 will Still he greyed out in the settings Tab but the monitor will display Good luck
I'm currently trying to figure out it I Can Rotate the tablet Monitor and keep the other monitor Un-rotated Any ideas?
Oct 19, 2010 | Toshiba Satellite R10-S802TD Tablet PC
I have toshiba tecra m2 when i had install the graphics card driver and restart my laptop the lcd screen disappears (blackens) while the whole system keeps runnig and i am using the correct drivers...
hi friend
Press F8 Just after you press the power button.
a window will open select safe-mode use the arrow keys to select and hit enter .then safely restore the computer using system restore.or uninstall the graphics Driver from control panel.the drivers that you were going to install was digitally signed?
this thing usually happens when you install an unsigned driver . click her to know hot to use system restore
please rate me
Mar 05, 2010 | Toshiba 25 PACK DIGITAL STYLUS PEN FOR...
Tecra M4-S435 Won't Boot
The GPU graphics chip fails a lot in this model. It usually means a motherboard replacement. I've had it fixed 4 times at a cost of $600 each time at a authorized repair center but it reoccurs a year after. The GPU fan doesn't come on enough to cool the graphics chip so it fires or gets unseated.
Jun 13, 2009 | Toshiba Tecra M4-S435 Tablet PC
Hardrive won't run, screen is black
Most possible one of your Toshiba Tecra m4 driver is not working properly, but don't worry give me a call at +1 (833) 493-0111 so that i can suggest you the right way to fix it!
Apr 13, 2017 | Toshiba Tecra M4-S435 Tablet PC
Toshiba tecra M2 LCD Screen
A pinkish tint is indication that the backlight tube inside the screen is not fully lit. But then it goes black - meaning the tube shut down? That part don't make much sense - it's certainly possible, though.
Replacing tubes is pretty surgical so I wouldn't recommend it. Replacing the screen should be pretty darn easy. A good, used screen should be pretty cheap on eBay, so that's where I'd start.
Jan 25, 2008 | Toshiba 25 PACK DIGITAL STYLUS PEN FOR...
Laptop won't startup!!
Problem with the BIOS. Please remove the BIOS batterya nd put it back. This link will guide you in doing so:
Sep 17, 2007 | Toshiba Tecra M4-S115TD Tablet PC
Toshiba Tecra M7 Tablet PC Logo
142 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
