Question about Protron PLTV-32 Television
HD compatibility - Not
Purchased this tv 2 1/2 years ago, and just this month got HD cable service, only to find that the set won\'t sync up with the 1080i feed from Comcast. Proton tech support says it's a Comcast problem. Comcast blames the set. I lean toward it's being a Proton problem.
I't connected with the comp cable and will only sync to 480 which is no different from Standard TV (except the picture is smaller.)
  • 1 more comment
  • BTBATTLE Jan 30, 2008
    hi i have same problem hd compatibitity not working
  • angelforever Sep 03, 2008
    I am having the same problem. I bought a HDTV 32 inch protron and for the past year I have been going back and orth with comcast and my warrenty company. When I have the settings at 16:9, 1080i and 480P tv looks amazing but when I go to the ON DEMAND menu my screen blinks blue and I can not even see menu. If I change setting to 16:9, 1080i, and turn last setting off, it works but is not optimal for best picture. ANY HELP OR ADVICE
  • ronmach Oct 15, 2008
    I have the same problem with Comcast 1080i feed. I plugged in the component cables to 3 different Comcast DVR boxes and used 3 different cables. The screen is scrambled when showing an hd channel, but is fine with standard channels shown in 480. By the way Protron Digital Corporation filed for bankruptcy in June of 2008. Phone number no longer works 888-257-8899. Good luck with this company!
  • 579 Answers
You need to nail down where the problem is by finding another source of 1080i signal and prove if it is the TV or not, then hold Proton's feet to the fire if it is.
Posted on Dec 31, 2007
How do I change my service from analog to H D?
Most LCD tv's built in the last 4 years are HD compatible. Most cheaper brands tv's are 720 HD and some are full HD 1080 a little more money. Since their is no more analog broadcast as June 2009 all tv's manufactured around 2006 started incorperating the digital tuner (DTV) along with the analog so that the tv would still receive analog broadcast while the digital transistion was ongoing. All tv's with a Cathode Ray Tube (glass picture tube) are not HD compatible. First you will have 1 or 2 ports on the tv ethier on the side panel or rear panel of the set. They a marked HDMI 1 HDMI 2 or HDMI A HDMI B. If you have these ports your set is Hd Compatible. You may also need to upgrade your cable or satelllite equipment and subscribe to a HD package to be able to get HD service. You will need a HDMI cable to connect your cable or satellite receiver to the HDMI port on you tv. Call your local cable or satellite provider for options to upgrade to HD. Most over the air broadcast stations depending on your area transmit some stations in HD free of charge. A good quality outdoor antenna works best to give you stable signal. You may need to change the settings of the tv as some sets default to the 480i this is the standard digital signal.
Sep 10, 2014 | Televison & Video
NO picture
Make sure the video cable supplied with the TV is secured to the correct video
output port on the back of the VCR and the TV. Make any cable you have attached
to the TV is secured to the correct output your Set-Top Box, DVD, etc.
Adjust brightness and contrast.
Check Source settings.
Let me know if this does not help and ill look for anything else. Other than this is something internal and will need to be serviced probably
Oct 20, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Viore LCD26V37HA Won't Work With Cable
where did you hooked up the cable box, how about the settings in the tv did you checked?.
Aug 15, 2012 | Viore Televison & Video
Greyish marks on Samsung 32'' LCD TV
it should be covered, can call 1-800-samsung for nearest authorized service center or go to samsung.com
Dec 31, 2009 | Televison & Video
Viore pdp42v18ha problem - no audio
Take it back to the dealer from which you purchased, receipt in hand and raise a stink.
Mar 04, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
BRAVIA TV KDL-40V2500
i had the same problem and the only way i could solve it was to disconnect power from the tv, let it "reset" then it would be ok for a bit. the problem went away entirely when the cable company updated its software for its hd box. might be coincidence....
also, pre-update, the resolution wouldnt automatically set correctly. If I turned on the tv to a hi def station, it would set to 480 and only set to 1080 when i changed to a normal station then back to the hd. then it was fine. again, after the update from the cable company this went away.
Sep 28, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Westinghouse 47"lcd tv
are you using an hdmi cable or the red blue and green cables that came with the xbox? if using the original cables there is a switch on them that sets it to HD or standard. hope that helps
Jun 06, 2008 | Westinghouse TX-47F430S 47 in. LCD TV
Sony BRAVIA KDL46S2010 Sound and Pix not in sync - in HDTV channels only
This is a software issue with both the TV manufacture and the cable box provider. This will only be fixed when the cable company and TV manufacture sit down and work out their problem. Some cable company has taken the first step by updating cable boxes with different software.
Best regards
CircuitCity
Nov 24, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Protron PLTV-32 Television Logo
112 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
