Bosch Axxis WFL 2060 Front Load Washer
Problem for Bosch Axxis WFL 2060 Front Load Washer
Display flashes e-13 will not drain
By tmittiga on Oct 21, 2009
display flashes e-13 will not drain
Best Solution
posted on Oct 21, 2009
Very Helpful)
gurus_view
Rank: Wiz
Rating: 92%, 15 votes
Hi tmittiga,
Check the drain hoses and pump That code is for a longer than normal drain if it did not drain it would not let you open the door,  You need to clean the filter. Remove the circular panel on the front right put a little screw driver in the hole and twist the access panel will pop off. Then you will need to twist the handle of the filter and pull it out you will find what is stopping the unit from draining in there very common. Also have a lot of towels handy all the water in the unit will come out when you pull the filter.
Regards
R.K.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Bosch Axxis WFL 2060 Front
Questions and Unsolved Problems for Bosch Axxis WFL 2060 Front
Do you recommend Bosch Axxis WFL 2060 Front Load Washer?
Answer
Answer
Bosch Axxis WFL 2090 front load washer: I find water in the drum twelve to twenty-four hours after I... (More)
Answer
power died mid-cycle with water still inside
Answer
I need to replace the door seal on a Bosch Axxis WFL 2060 and and need any tips/advice on doing... (More)
Answer
Drum doesnt always turn through full cycle. It appears that the slightest out of balance causes the... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
