Home | Adobe | Photoshop CS (23101764) for PC | Where is the dodge tool?
Adobe Photoshop CS  for PC
Problem for Adobe Photoshop CS (23101764) for PC
By shellykaymor on Oct 21, 2009
where is the dodge tool?
Solution #1
posted on Nov 05, 2009
Not Rated)
Broken_toes
Rank: Master
Rating: 100%, 1 votes
Dodge tool should be on your toolbar- its like a black circle with a little line coming down diagonally from it- shares a button with sponge and burn so may be hidden behind them. Left hold click if it is that should bring up a little drop down that will let you select the tool you need.
Other than that, a much much better way to dodge/burn is to use layers- go to layers (top of the screen beside file, edit, etc)
select new->layer- this should open a box.
Now- set the colour drop down to none
Mode drop down- Set to soft light, feel free to experiment with hard light etc
Tick the soft light neutral colour (50%grey) box- should be at the bottom of the box.
Set opacity to somewhere between 5 and 10 %.
Click OK
This puts a new layer over your image, now you can use the paint brush- set your colours to black and white, you use white to dodge black to burn.
Though this may sound complicated, it soon becomes second nature once your used to it and gives you alot more control of your dodging and burning- leaving you with a much more 'natural' image. Once you get the hang of it you can add new layers (using the same process i went through above) to slowly build up your dodging and burning- changing the opacity level in the layer box to a higher setting means you put more paint on the image- your burning will be darker, dodging lighter.
Using mulitple layers also allows you to take away a dodge layer if you think you have gone to far- and saves you stepping backward when you mess up- its almost like painting.
Was this helpful?
Yes
No
Popular Solutions for Adobe Photoshop CS for PC
Questions and Unsolved Problems for Adobe Photoshop CS for PC
Do you recommend Adobe Photoshop CS (23101764) for PC?
Answer
Answer
auth code for serial # : 1045 - 1083 - 4312 - 9646 - 0228 - 9319 ACT # : 1045 - 1083 - 4312 - 9646 -... (More)
Answer
i need the authorisation key of adobe photoshop cs8
Answer
I created a blurred layer then added a black layer mash by holding down Alt and clicking on Add... (More)
Answer
SN : 1045 - 1085 - 6610 - 5394 - 9391 - 9263 AN : 5106 - 5813 - 7208 - 8964 - 9505 - 8098 - 3244 AT... (More)
Answer
serial Number :1045 - 1084 - 3377 - 5725 - 2191 - 9202 Activation Number : 7310 - 6353 - 7719 - 9139... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Adobe Photoshop CS for PC:
Top Graphics Pub... Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Graphics Pub... Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
