Question about Maxtor Personal Storage 3200 (M1227310) Hard Drive
How to add to
How do I add to the existing it automatic or is there something I need to do? thank you...
0 characters
1 Points
My Iomega mx mobile mass storage player has stopped sending signal through HDMI cable to TV all other functions are ok. HDMI cable changed still no picture
You need to try some tests.
  • Does the same cable work with any other TVs
  • Do any other devices work on your existing TV ?
You also need to check that you have set the output of your device to HDMI and the input of the TV to HDMI. In the past the TV may have automatically selected HDMI when the device is turned on but sometimes that does not work.
Mar 23, 2014 | Iomega Hard Drives
I have a problem in my flash drive because i can save any files beacause it is write protected. what shoul i do to remove its write protection???
Hello Evitan,
From Start Menu >> Run, type regedit and this will open the registry editor. Navigate to the path below :
If the registry key Storage DevicePolicies key does not exist, you will need to create it.
Download the batch file called add.bat from below link, and double click after download the key will be automatically added to registry.
Double click the key Write Protect in the right pane and set the value to 0 in the Value Data Box and press OK button. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.d set the value to 0 in the Value Data Box and press OK button
Aug 18, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Write protected cannot format the usb.
try to remove partition on to disk management tools and make new partition then reformat the USB drive be careful not to delete the other drive.. or use a software that can manage drives like paragon or acronis partition manager .
Hi experts, my computer indicates there's only 1,14 gb space left on my usb stick but really there's only 8 items on it that don't even add up to 1 gb all together. I want to put a movie on it, (there...
Most movies are about 4.5GB to 8GB, this is probably why your not able to put a movie on it. Secondly a lot of flash drives say its 4GB but really its 3.5-4GB. There must be something your overlooking as file size for ti to take up that much space. go to the properties of each file and look at the folder size, might find something you missed that's taking up more space.
May 03, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
I need a complete 3200 Maxtor 200GB Personal External unit -- case and all, not just the HDD according to my friend. Is this right?? I do not have the existing case as this was discarded when it was opened...
Hi bizemail,
Well, I'm not sure why you discarded the old casing. If you recieved a replacment from Maxtor, they would require the drive and case, or your warranty would of been voided. Your not suppose to open those cases. However, now that you have, you can test the drive by just loading it your computer (desktop I'm hoping) as a slave drive. Make sure your pin settings on the other drive is set to master, and add it in. If it works Windows will find it and add it as new hardware. If it doesn't, then their something wrong with the drive. I'd call whomever you purchased it from.
Good Luck,
And don't forget to leave a rating,
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Cannot get automatic storage and update of files on to WD Passpor
There is a Backup in XP but its well hidden - go to Start, Programs, Accessories, System Tools and you will find it there. If not, it may not have been installed when XP was loaded on your system.
If you want to try something else, Google on " Free backup programs" - that should turn a few up.
Feb 02, 2009 | Western Digital Passport WDXML800UE...
Maxtor 3200 External Hard Drive
That happens when your computer was infected by virus, have it scan, it will be good if you can use different scanner aside from what is installed in your computer.
Nov 20, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Does maxtor 3100 storage automatically add file to itself?
Yes, it is wise to do a house cleaning on your Maxtor. Whether you delete everything or not is up to you. However, do not do this by formatting the hard drive.
If you find you need a file later you deleted from the drive, a free program called 'FileScavenger' can recover it for you. If you format the hard drive the ability to recover a file becomes highly unlikely.
We techs have expensive software to recover files should you need to get it retrieved, but the interface is designed for techs and not the average user.
Jun 08, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Open Questions:
See all Maxtor Personal Storage 3200 (M1227310) Hard Drive Questions
Maxtor Personal Storage 3200 (M1227310) Hard Drive Logo
15 people viewed this question
Top Maxtor Hard Drives Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Maxtor Hard Drive Expert? Answer questions, earn points and help others
