Kenmore washer 60 series
I have a washer that worked fine and had no problems until I washed a set of pillows. The washing machine quit working and remained filled with water. The machine will not spin to remove the water. Is there a reset button or some type of switch that needs to be repaired or replaced? Is so where is it located and how do I access it? I do not have a service manual.
  • 1,314 Answers
Lid switch proably bad look on your lid will see a plastic piece sticking down that goes into a slot in the waser body the switch is in there should be up aginst the washer body so that peice can push it down its grey or white if its not horizontil you might be able to take a pencel push down on that switch put the washer on spin and drain it then get back to me by replying if it works for repair
Posted on Dec 30, 2007
Same exact thing happened to me. Worked perfect. just remonve the two screws an pull the switch out. I saw right away mine was broken. I jammed a piece of pencil in it to hold the switch in the "closed" position. I was about to go buy a new washer!!!!! Thanks!!!!!!!!!!
Posted on Feb 06, 2011
Kenmore 60 series washer won't pump
The lid switch will not allow the motor to pump out the water. Including timer issues. So start looking for the problem respectively.
Feb 07, 2014 | Kenmore Washing Machines
My kenmore 500 series will not drain the water.
the pump is probably clogged with pillow fluff...
Jan 15, 2010 | Washing Machines
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Hi, thanks for using the FixYa service. Your lid switch is probably broken. Make sure you can hear it click when you open and close the lid. It it is a very common problem on that model. Probably has nothing to do with the pillows, that was just the last load in the machine before the common part failure. Get me the exact model number and I can get you the replacement part number.
Dec 19, 2008 | Kenmore 24032\24036 Top Load Washer
Tub leans to the right when washing the clothes
I washed pillows in my washer and now the tub leans to the right front. And my dryer needs to have the lint cleaned out of it. How do I do this. They are Kenmore 80 series washer and dryer
Nov 23, 2008 | Maytag HAV3460AWW Top Load Washer
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
402 people viewed this question
Top Washing Machines Experts
