Question about Sharp 27N-S50 27" TV
Sharp 27 inch color tv... model # 27N-S50
On the back of the tv, the cable connector broke off while my wife was trying to move it, broke off...... i took the back off and sodered it back on but now the picture will only stay on for a few min. then go off and on. i might of melted some soder down and touching something else, is there any way i could hook up the tv with audio and vidio in the pack to my cable converter?
2 Suggested Answers
MikeNJ1964
  • 398 Answers
SOURCE: Missing Cable Connector
After you remove the tuner from the main board and remove the 2 covers from the tuner, straighten the metal side of the tuner where the hole is for the F connector. If you look at the PC board inside the tuner, there is a small hole in the board directly under the hole in the metal for the F connector. Usually there is a small piece of the old F connector's center pin still soldered in that hole. If it is there, unsolder it and throw it away. The new F connector will be soldered in place over the hole in the side and a small jumper wire soldered from the center pin of the new F connector to the little hole in the PC board directly under it. Be careful when soldering on the tuner's PC board because the parts are extremely small and close together, and lost SM parts and solder bridges are possible. Be sure none of the coils in that area have been squashed over, which is what I usually see when the costomer sticks something in the hole left in the tuner. If the coils are squashed, you can straighten them with a small pair of tweezers or remove them and rewind then around the proper size drill bit. Let me know how you make out.
Posted on Aug 11, 2007
No audio
1 Suggestion, turn this off and leave UNPLUGGED for a few minutes then plug the power back in. Try that, have you also tried connecting another device like a DVD player in?
Aug 21, 2017 | Sharp 27N-S50 27" TV
I have a 27N-S100 TV. It was given to me with no remote. The Cable plug thing in the back is completely broken off, but I was told the TV could work perfectly by using the 3 colored cables (I believe they...
What you're trying to do shouldn't work unless the VCR has a digital tuner in it or your cable company still hasn't converted over to digital as of yet. You will need to get a digital cable box from your cable company.
Connect the av cables to either the front or back of the television. I believe the front is av/video 2 and the back is av/video 1. You have to choose either video 1 or video 2 from the television's menu in order to access these parts of your television.
Connect the cable box to the other end of the av cables and you should be all set. You would change channels with your cable remote and always leave the Sharp television on video or
What you're trying to do: Connect the cable to where it says in on the back of the vcr. and connect the av cables to the vcr where it says out. You will have to do a channel scan on the vcr.
Apr 26, 2011 | Sharp 27N-S100 27" TV
How to hook up headphones to a sharp 27ns100
It looks like your TV has stereo AUDIO OUT jacks on the rear panel (L and R) which you can use to connect headphones. Go to a local Radio Shack or other electronics retailer and ask for help with the required adapter cable and connectors. They should be able to direct you to the product(s) as Radio Shack has these simple adapters and they should cost very little. All you need is a simple RCA cable with the white and red plugs for the TV side and depending on your headphones, either a 3.5mm or larger connector for hookup on the headphone side. They also sell extension cables so you can move away from the TV more. Don't let them sell you anything fancy or expensive as this is really simple.
Mar 14, 2011 | Sharp 27N-S100 27" TV
Sharp 27N S50 need universal remote code
You didn't mention the brand of your remote. Anyway try the code below.
SHARP Codes: 004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Try the 3-digit code at a time.
Hope it may help you.
Have a nice day!
JDVillanueva
Feb 04, 2011 | Sharp 27N-S50 27" TV
I was given a Sharp 27N-S100 27" TV. Everything's fine but I don't have the remote control or user manual. I would like to get to the menu screen for the tv. How can I do this. Its hooked up to a cable box...
On the front of the TV you should be able to press both channel up and down at the same time and it will give you access to the TV menu. Once in the menu use the channel and volume up and down buttons to navigate.
Good luck....
Jan 13, 2010 | Sharp 27N-S100 27" TV
2001 Sharp TV MODEL NUMBER 27N-S300
Click here to download the user's guide and go to page # 21 or read everything about disabling the V chip feature.
Aug 05, 2008 | Sharp 27N-S300 TV
SHARP MODEL 27N-S100
Flyback part number RTRNF0033MEZZ
Nov 10, 2007 | Sharp 27N-S100 27" TV
Aug 09, 2007 | Sharp 27N-S50 27" TV
Sharp 27N-S50 27" TV Logo
111 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
