Home | Rinnai | Desa Vent-Free Infrared Gas Heater: Ven... | I have a 5 year old glo...
Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater
Problem for Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free...
I have a 5 year old glo-warm ventless
By dreed22 on Oct 21, 2009
i have a 5 year old glo-warm ventless heater(propane)that needs a new thermocouple. the old one has an extra wire soldered to it that looks like a grounding wire? all the replacement thermocouples do not have this wire. is it needed?
Best Solution
posted on Oct 21, 2009
Very Helpful)
robo_geek
Rank: Guru
Rating: 92%, 46 votes
Since the thermocouple body is made of metal, and often these have a copper or brass sleeve, that *should* provide good grounding for the thermocouple.
Obviously some engineer at the heater company did not agree with this, so he added an extra ground wire.
Most gas valves are not all that sensitive to exactly how many microvolts the thermocouple feeds to it.
My guess would be that if there is a cheap metal bracket that holds the thermocouple, such as unplated steel or tin, the extra ground wire counteracts the effects of corrosion over time.
So if the heater were stored in a damp garage, the thermocouple connection would get corroded, and the heater would not stay lit. The fix is the extra ground wire.
There are two types of failures with thermocouples: the safe-failure is when the gas is shut-off, even when flame is present, and the unsafe failure would be when gas is not shut off, even when no flame is present.
If the thermocouple somehow was not adequately grounded, then the most likely failure would be a 'safe failure' , such that the burner would not stay lit.
You could rig up some sort of extra grounding wire, but unless the part is subject to extreme vibration or is in an extreme (wet/salty) environment, it's probably not needed.
Of course, to be safe, do a flame blow-out test after you install the new part. While it's highly unlikely that an unsafe failure could occur, better safe than sorry.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Rinnai Desa Vent-Free Infrared
Questions and Unsolved Problems for Rinnai Desa Vent-Free Infrared
Do you recommend Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater(18,000 BTU)?
Answer
Answer
I have a ventless Vermont Castings LP burner - the pilot light goes out when you turn the knob to... (More)
Answer
I purchased a house with a Glo-Warm ventless heater. It is a FS-3B serial # 8776421 and the knob is... (More)
Answer
Pilot light is always going out on my Desa vent free stove. Cleaned the pilot assembly and it still... (More)
Answer
i have a adesa model cbn 20t serial 014970796 when i hold the button down on the pilot light for 60... (More)
Answer
where can i purchase a thermocouple for this gas heater? no carries them since the company went out... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Rinnai Desa Vent-Free Infrared...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
