Question about Brother HL 1440 Laser Printer
Alarm button on and unable to print
I checked for paper jams, bought a new toner, reinstalled the program but the printer won't print. Any solutions?
  • Brother Master
  • 1,113 Answers
If your using after market toner well then we just found your problem, replace with genuine product.
Exact definition of lights that you are seeing is really required here please see definition of lights and post back.
Posted on Dec 30, 2007
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
The red light is on and won't print, nothing is jammed and all parts closed. How do I resolve this and get the printer to work again.
Hello A Barr,
Welcome and thank you for using FixYa!
To answer your question: Red alarm lights constitute a full-stop alarm to a printer. These are usually caused by fuser errors, paper jams, and formatter board errors.
I would begin testing by removing the toner cartridge and checking underneath every plastic and metal plate between the paper drawer and the toner cartridge. If you pulled out a peper jam backwards (back down into the paper tray area) you could have paper that ripped off without seeing it. Examine closely.
If you don't find a jam, check the little plastic sensor flags along the paper path. one may have broken off.
If you can't locate a jam, then remove and examine the fusing section (fuser) for torn a teflon roller or paper jams. It is also possible that the bulb in the fuser may be blown out. Chances are a "Maintenance Kit" with Feed Rollers installed properly, will fix your issue. The formatter board would be the last and most unlikely place one would be pushed to examine.
Have a great day!
Oct 10, 2011 | Dell 1110 Laser Printer
Wont print ready light and alarm light flashing
When the printer "Ready" and "Alarm" LEDs flash as shown, please check the following points:
1.Paper Jam: Clear the paper jam referring to "How do I clear paper jams?"
If the printer does not automatically resume printing, press the control panel button.
2.No Paper/ Misfeed:
-The paper cassette may be out of paper or not properly installed.
-If it is empty, load a new stack of paper into the paper cassette.
-If there is paper in the paper cassette, make sure it is straight.
-If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
-Reduce the amount of paper in the paper cassette, and then try again.
-Make sure you use paper that meets Brother's recommended paper specifications.
-Reinstall the paper properly, and then press the control panel button. The printer will start printing again.
Dec 06, 2010 | Brother HL 1430 Laser Printer
Printer stopped working. I just added new ink supply. Alarm light flashes. Printer status says "service error 6A00"--"check printer" "cancel printing and press the ok button." None of this works. And I...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Apr 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
New toner cartridge and paper jam
Does this happen when you install the old toner? Is the NEW toner an OEM or compatible? I have run into this problem before on some other Brother all in one models. There is a sensor flag located just below the toner and drum unit. Remove the toner/drum unit, check that the sensor flag will move to back and forth freely. My customer removed the toner and drum unit and threw the drum unit away, not realizing that the toner seats into the drum unit. When they placed just the toner into the printer, it read paper jam. Because the drum unit is part of the paper path, the sensor was not in the correct position.
Try re-seating the toner into the drum unit and then re-seat the entire unit into the printer. Let me know if this helps.
Oct 20, 2008 | Brother DCP-7020 All-In-One Laser Printer
Brother printer problem
Manual Feed Command.
1. Press the Job Cancel button to cancel the print job. Delete the print
job in the print queue on the computer. You can quickly access the print queue by double clicking the Printer icon in the task
tray or dock.
2. Turn the printer power switch OFF on the right side of the printer.
Check that the front cover is closed.
3. Turn the printer power switch ON while holding down the GO button
until the Toner, Drum, and Paper LEDs are lit.
4. Release the GO button. All LEDs will be off.
5. Press the GO button 8 times. The green Status LED will flash briefly
while the printer is reset. After the printer is reset the Status LED
will be lit green.
6. Print the Print Settings by pressing the GO button three times. If
the Print Settings pages do not print and the Paper LED is on again skip
to the next section - No Paper in the Paper Cassette.
If the Print Settings pages print, the problem is isolated to printing
from your computer. The Paper Source of the Brother printer driver or
program you are printing from may be set to MP Tray or Manual, instead
of Auto Select, Tray 1, or Tray 2 (if the optional paper tray is
installed). To check the Paper Source setting of most programs, click
File and Page Setup or Page Layout. You may need to click the Paper
Source tab or Paper tab depending on your software application. Verify
that in the Paper Source section does not list MP Tray or Manual. Choose
Auto Select, or another relevant source such as Tray 1. Click OK. Try printing the document again.
No paper in the paper cassette.
1. Pull the paper tray completely out of the printer.
2. Insert the letter or legal size paper into the paper tray with the
top edge of the paper first and the print side down. Make sure that the
paper is flat in the tray and below the maximum paper mark. If using a
paper size other than letter or legal, the paper should be loaded in the
MP Tray. The MP Tray can print on paper from 2.75 in. by 4.57 in. up to8.5 in. by 16 in.
3. While pressing the blue paper-guide release lever, slide the paper
guides to fit the paper size. Make sure that the guides are firmly in
the slots. For legal size paper, press the lever located at the back of
the tray and pull out of the back of the open tray.
4. ReinstalI the paper cassette back into the printer. Press the GO
button. If the alarm clears, no further troubleshooting is needed. If
the alarm continues, follow the steps below.
Paper Jam at Paper Pick-up.
1. Turn the printer power switch OFF on the right side of the printer.
2. Remove the paper cassette from the printer.
3. Elevate the front of the printer slightly to locate the jammed
paper.
4. Gently remove the jammed paper.
5. ReinstalI the paper cassette back into the printer.
6. Turn the printer power switch ON. If the alarm clears, no further
Oct 02, 2008 | Brother HL-2040 Laser Printer
Alarm and data lights are both on and when i go to print nothing happens
take y'r drum and toner out of the printer.. now there should be two translutent white circular film on either side of your toner... what u have to do is take a small piece of paper and make a bead out of it and insert that small paper bead right in front of those film.. u can insert on both side or on just one...
if u don't find those circular film then open y'r HL printer toner loading tray and turn y'r printer ON.... u will see green or red light coming out of either side of y'r printer where toner sits.. thats the place u should look for those film on y'r toner....
it worked for me... hope it works for u too...
PEACE..
Mar 15, 2008 | Brother HL 1440 Laser Printer
Laser Printer HL-1440
Hi , The error message your getting refers to the following for the Ready & Alarm Buttons Flashing.
1. Paper Jam
2. Misfeed
3. No Paper
I hope this helps!!
Dec 05, 2007 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
60 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
