Question about Sony PlayStation 2 (PS2) Console
Ps2 my ps2 plays all the games in black and white
  • Anonymous Dec 26, 2008
    I am having the same problem as well. My tv isnt but a year old so surely that cant be the problem. Any other suggestions?
    New Friend:
  • 14 Answers
Well, I can tell you it is highly unlikely that your new T.V. Is the opportunity in this case. It might be one of the following things:
1. The video port of your PS2 might be bad.
2. The video card of you PS2 is going dead.
3. The cable you are using is bad.
4. Your hooking up the cables wrong.
5. Your T.V. Is on the wrong setting.
Hope this helps!!
Posted on Jul 15, 2013
Hi.even i had the same problem. the problem is with your tv set and not with your ps2.
it will be the same old ntsc problem.even i had the same problem.the problem is that your tv set is old .
the older tv sets had only pal support and hence it can play only in black and can try buyin a ntsc to pal converter if your ps2 is a ntsc model or the pal to ntsc converter over the pretty cheap.
if it doesnt help then the ultimate way is to buy a new tv set.
Posted on Oct 23, 2008
It maybe due to your scart lead in the back of your tv or the other end of the scart lead at the back of your playstation 2 try pushing them in a little bit more...i hope this info is helpful if so please leave feedback..
Stuart Mac Namara...
Posted on Jan 07, 2008
Try setting your tv's color the way you want it but the problam with that is you have to reset it every time you switch to tv to ps2...
Posted on Dec 31, 2007
  • 709 Answers
SOURCE: My PS2 will not play PS2 games, but it will play PS1 games
If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. REmove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. REmove the little white disc from the Cd tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and your in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact
Posted on Nov 05, 2007
  • 326 Answers
SOURCE: PS2 in black & white?
Hello Staubs, please look at the back side. There should be a sticker with the model (for example SCPH3XXXX). So please, which model is it? Thank you, Arpad
Posted on Dec 23, 2006
SOURCE: PS2 Locks-up during running
Maybe the TV is old or the disc is scratched
Posted on Aug 26, 2007
  • 3 Answers
SOURCE: showing black and white instead of color.
just set your tv setting to auto and it should be able to play colour again...
Posted on Jul 25, 2008
  • 456 Answers
SOURCE: why would my ps2 screen only be in black and white
Make sure that you have the plugs in the correct sockets on the back of the television , as well as make sure the tv is on the correct setting, NTSC, PAL, SECAM, etc. Good luck.
Posted on Nov 25, 2009
My ps2 on start up show a flickering black and white screen that you cannot read and will not play a game but it will play a brand new game out of the box once you get past the black and white flickering...
Ok are you sure it is set to the TV's & PS/2's Video Format, it is either PAL, or NTSC? Check that. ON BOTH TV & PS/2 and it must be same on both. Or AUTO. just a thought.
Jun 06, 2010 | Sony PlayStation 2 (PS2) Console
How to play ps2 games on ps3
Ok well here is the "Skinny" 1). 20GB has no chrome trim, no memory card reader and no wi-fi. Not manufactured anymore. Has the best backwards compatibility with PS2 games due to Emotion Engine (PS2's CPU) and Graphics Synthesizer (PS2's GPU) installed.
2). NTSC 60GB has the same backwards compatibility as 20GB version, also has memory card reader and wi-fi. Has a chrome trim.
3). 80GB - extended memory, but reduced backwards compatibility with PS2 games, it has only Graphics Synthesizer (PS2's GPU). Around 80% of PS2 games can be played. Available only in NTSC regions.
4). 40GB - can't play PS2 games at all (all PS2 chips were removed), has 2 USBs instead of 4, no memory card reader, has wi-fi. Avalable in black and white colors. White is on sale only in Japan. Uses 65nm technology (lower power consumption). Improved cooling system. It's the latest version. 40GB doesn't support SACD.
5). PAL 60GB - reduced backwards compatibility with PS2 games. it has only Graphics Synthesizer (PS2's GPU). Around 80% of PS2 games can be played.
Wi-fi included in all models, except 20GB.
Feb 05, 2010 | Sony PlayStation® 3 (80GB) Console
Playstation 2 is in black and white
ps2 goes black and white on plasma tvs
Nov 01, 2009 | Sony PlayStation 2 (PS2) Console
Ps3 wont play ps2 games
ps3 games are not supose 2 play ps2 games
Jul 25, 2009 | Sony Playstation 3 (PS3) Console
Ps2 slim black and white
i had a standard av cable with a "euroscart"adaptor.i changed it to a full euroscart cable for ps2 and it solved it.thanks for the help
May 16, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 Playing in Black and White and side scrolling.
Scrolls to the side or vertically?
If it scrolls vertiacally I get this from running PAL games on an NTSC TV,
Is this an import game?
Does the game disc and the console show the same video type?
PAL or NTSC. For the game (at least in the US) it shows the video type on the Disc under the PS logo and on the case it is at the bottom of the spine and the top right corner (under the PS logo) on the cover. On the console it should be on the laebl on the back of the machine.
Is the machine modded, such as having a modchip in it or softmodded with HD Loader or USB Advance?
Those programs should allow you to play the games just fine. I have several out of region games on my system and they all work just fine..
Apr 05, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 plays only in black and white
Get a new cable for the PS2...Theyre cheap
Feb 24, 2009 | Sony PlayStation 2 (PS2) Console
Have a Konka TV but ps2 doesnt play through it.
It may be the T.V. And make sure that the connections are with the right colors, take a light back there and check to make sure. You said the T.V. plays through black and white, maybe the T.V. is old and can only play black and white but those cables will not make a T.V. go to color.
Jan 29, 2009 | Sony PlayStation 2 (PS2) Console
Showing black and white instead of color.
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!
Dec 25, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
246 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
