Question about Cameras
Memory card problem
When i switch on the camera. A message automatically comes up....Card is not formated, press YES or NO. If i click YES then i will loose all my personal pictures saved on my memory card...When i click NO..It askes me to switch of the power. When is switch offf then on again the same message keeps on appearing and will not allow me to view alll my images or to take a picture...I need help...what do i do!!????!!!
  • dgame Jan 02, 2008
    when i cut on my camera all it says is power off and format. i press format and i says card error. when i take my memory card out every thing works, but i have alot of pictures on my card.
  • Anonymous Feb 10, 2008
    same as others, except being a new card it has nothing on it, and when i click yes to format it,comes up wth card error
Have you upgraded mem above 512mb. 1 & 2 gb cards state that the are not compatible with the f700
Posted on Jul 03, 2008
Memory card formatting
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
Aug 02, 2011 | SanDisk 1GB microSD Memory Card
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
Apr 12, 2010 | Samsung S630 Digital Camera
Nokia N70 automatically send messages which displays in outbox folder. It automatically takes number from my contact list & start sending message to that number whether their number is landline or...
Your phone is infected with HatiHati.A malware. It is a worm-like application that spreads via MMC cards. Once the worm copies itself to a new device, it starts sending SMS messages on its own. Here's the DIY cure:
Note: This will erase all data stored on your memory card and phone. Copy contacts from phone to SIM card. Make sure the battery is fully-charged before proceeding.
  1. Format your memory card.
  2. Navigate MENU > TOOLS > MEMORY.
  3. On the memory card menu press OPTIONS.
  4. Scroll to Format memory card.
  5. Once the formatting is complete, remove the memory card.
  6. On your phone dial *#7370#.
  7. Press Yes then enter your phone lock code. Default code is 12345.
  8. When the phone restarts, insert memory card the format it again.
Please let me know if you need further advice.
Nov 20, 2009 | Nokia N70 Cellular Phone
It says picture error for every picture and cannot delete photos individually. One minute it said card full then every photo said picture error and switched itself off. Its not a happy camera
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the picture error messages and the card can be used again.
Apr 27, 2009 | Olympus FE-190 Digital Camera
Error message on olympus camera
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Apr 20, 2009 | Olympus Stylus 710 Digital Camera
Memory card cannot read by digital camera.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - go to format option- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Mar 22, 2009 | Olympus Cameras
Hello, we tried to download all our pictures on to the computer but it seem that the whole memory card got deleted and now all the functions are locked. It gives us the message that the xD card is "write...
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup- Press Ok- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Jan 19, 2009 | Olympus Mju 790 SW Digital Camera
Stylus 600. When I turn camera on a blue screen comes up with a message [xD] Write Protect. What does this mean and how do I make it go away?
In order to remove the message of write protect you will need to format the xD memory card. The card has somehow become corrupted. To format the memory card - press Ok - right arrow to Mode Menu - down arrow to Card tab - right arrow to Card Setup - right arrow to Format - Up arrow to Yes and then press Ok. This will permanently delete all images from the memory card and you will be able to start taking images again.
Jul 12, 2008 | Olympus Cameras
Card Locked?
There is a switch in the memory card, you just have to slide it upward.
If you are using a new memory card, format it first.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2
- Select Format
- Select Yes
Nov 13, 2007 | Samsung Digimax S630 Digital Camera
Cameras Logo
71 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
