Question about Apple iMac RAGE PRO/233/266/333mhz Logic Board (p/n 661-2113-R) Motherboard
IMac 266 Rage Pro Won't Boot
I can only seem to boot my iMac (a Bondi Blue Rev A or Rev B) from an OS 9 or higher CD, but I can't install OS 9 because I have to update the ROM. To do that, I have to be able to boot and install OS 8.6, but I can't.
Also, when booting the keyboard works until the Desktop is loaded then the keyboard disappears.
Right now, the HD is empty - formatted and ready to go.
Also, I can't use the keyboard once in the Open Firmware. I've tried every trick and tip imaginable and I just can't get it to work!
If I have OS 8.6 loaded as a network share, can I run the 8.6 Installer (even if I booted from an OS 9 CD) from the Share and make this thing bootable?
  • EvilSupahMac Jan 02, 2008
    I looked up the serial number, and it comes up as a Rev. B, and according to the documentation, The minimum it will boot from is 8.5, so, once I have an 8.5 CD, I should be up and running in no time.
    Problem Solver:
  • 4 Answers
It can be deployed over the network if the information is placed in a Winzip folder first.
Before trying to install the 8.5/8.6 program, did you double check the HCL?
Some systems require you to install the 8.5 first, then upgrade to the OS9.
Posted on Jan 02, 2008
  • 667 Answers
I don't think the installer will work over a network. I think you need an actual CD of 8.5/8.6 or an external drive with the OS on it.
Posted on Dec 31, 2007
  • Kevin Pettit
    Kevin Pettit Jan 02, 2008
    The HCL refers to Hardware Compatibility List. It is for WIndows based machines, not Macintosh.
    You already know you need to update the ROM firmware to install OS9.
    I would buy a copy of 8.5 on CD, there is one on eBay for 25$. Install it, upgrade to 8.6 and then try the firmware update. You can always resell the 8.5 CD once you are through with it.
Pro-book 4520 won't boot. I switched on this morning. The windows (7) logo appeared, then blue/black screen and cursor only. Would not boot up. Ran diagnostics which said all OK. Still won'
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
Aug 13, 2012 | HEWLETT-PACKARD ProBook 4520s Notebook PC
My computer won't boot from the new disk warrior
Usually three beeps indicate a problem with the RAM, reseat the RAM and then try to boot up with disk warrior. Hope this hels.
Mar 27, 2012 | Computers & Internet
I put in the cd to install this program and I only see files and scripts nothing comes up and allows me to install the actual program. I tried it on my pc and it worked but I didn't install it into...
Sounds like you have a Windows exclusive CD. It will not work on Mac OS.
If you have a windows install disk, you can install Windows on your Macbook Pro using Boot Camp via the Boot Camp Assistant located in Applications/Utilities. This will require you to restart and select one desired system to boot up in order to use OS X or Windows.
Alternatively you could run Windows and Mac OS simultaneously with a program such as parallels.
Jul 21, 2011 | Computers & Internet
I have install windows 7 on my macbook pro and then mac programe can't run and sound speaker can't work
restart your computer then hold the COMMAND key then the option for your dual OS pop-up.. hop it helps
Jun 29, 2010 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
Imac g4 won't start but shuts down when apple logo appears on screen
Are you sure the iMac is really shutting down or just turning off the backlight? The tell-tale sing would be to let the unit fully boot-up (wait 3 minutes) and the press the button the apple keyboard that ejects the CD-ROM. If the CD-ROM door opens, you iMac is running with disabled or broken backlight.
The inverter circuit on the iMac G4 is known to be weak.
There could be another problem, though. The iMac G4 is also known to have weak internal power supplies. Here's how you can tell:
Hold down the CMD OPT "O" and "F" keys at the same time while pressing the power button. This will tell the iMac that you want to boot into the Open Firmware shell, bypassing the Mac OS X startup. If this works, your power supply is good, the inverter is good and you have a problem with your Open Firmware boot string. To fix the boot string, Power on the unit while holding down the keys CMD-OPT-P-R to zap the parameter RAM (PRAM) and reset everything to defaults.
If you were not able to boot into the Open Firmware shell, your problem is either a failed power supply or a failed screen backlight. The last possible culprit is your iMac could suffer from "Bulging Capacitor Syndrome", where a batch of iMac G4s, iMac G5s another electronics were fitted with a bad batch of capacitors. Eventually, the caps will rupture and cause irreparable damage to the logic board. Only way to verify this is to pull the unit apart and visually inspect. If you see little green or blue cylinders that seem to be bulging or oozing a thick oily goo, that's your problem. Only recourse is to shop around on eBay and look for a replacement logic board.
May 30, 2010 | Apple iMac G4 Desktop
IMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
If it only boots to a blue screen, try booting up in Safe Boot mode:
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
May 18, 2010 | Apple iMac G4 Desktop
Can't get imac to boot up everything looks fine then I get a black box with white lettering saying error in start-up . code number post/16/2048DIMMO/J22, thanks for any help. I ran the hard-drive test and...
Sounds like a kernel panic code. You may be missing a piece of the OS code due to a Hard Drive error from a power issue or whatever. You may need to reinstall your OS. Start up from the cd and save all your data you can to a flash drive or external hard drive and then do a clean install.
Jul 16, 2009 | Apple iMac G4 Desktop
Problem loading an OS onto a Dell XPS One 2010
May 15, 2009 | Computers & Internet
Locked G3
Time to completely erase the hard drive.Start up from your install CD with latest version that will run on this Blue and White.. Don't expect to save any existing files. Just do a complete erase and reinstall via disk utilitly and then your os disc... let me know how it goes..
Mar 14, 2009 | Apple Power Macintosh G3 (Blue and White)...
Computers & Internet Logo
209 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
