Question about Panasonic KX-TG6700 Cordless Phone
Talking caller Id says names backwards
My caller id when someone callls it says the names back wards what can do to change this?
SOURCE: KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Posted on Jul 27, 2008
  • 2460 Answers
SOURCE: panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Posted on Dec 05, 2008
SOURCE: talking caller ID won't stop
I dont know what your talking about i love the talking caller id on my panasonic lol its kewl like im somewhere in the house and i just hear who is calling dont even have to go unstairs or inside to answer but anyways. Theres 2 options. One is when you go to the menu(Thats only for the handset). You also have to go to the menu and then the initial settings and look for an option somewhere there like base settings or something
Posted on Mar 16, 2009
  • 89 Answers
SOURCE: Talking caller ID Want to turn it off on base unit!!
You have to press "Menu" "#" then 1 6 2.
You can also just press menu and then scroll to talking caller id, select it and then choose to turn it off. Be sure to press "save" or the your choice will not be saved.
Posted on May 18, 2009
  • 61 Answers
SOURCE: TALKING CALLER ID is set to OFF , but is sill working... I cannot disable
ask your network provider to turn it off for you?
Posted on Jun 01, 2009
SOURCE: caller ID/CLIP) not working in Panasonic cordless
Well if the phone has been bought abroad and being used in India you will face this problem. this is because of the format of transmitting the caller id info being different. In USA it is STF and in India it is DTMF. You need a convertor in the phone line which is DTMF to STF. IF you find onw in Delhi pl let me also know.
Posted on Sep 25, 2009
0 characters
1 Points
Caller id will not show on the display.
Did you change carriers? A lot of the VoIP carriers like vonage and magic jack will only give you the telephone number on caller id, but not the name.
I have magic jack now and they call that "caller id", but having moved from a carrier that had name attachment i assumed all caller id's had name and phone number both...but not so
Mar 09, 2015 | Panasonic KX-T7453 Corded Phone
Sakar talking caller id doesn't work!! ringer doesn't work, have it on. taking caller id doesn't work. Need someone to help with this.
Did this just suddenly happen?If it did,unplug both the phone line and the power supply for about 5 minutes.The transformer needs to be unplugged from the wall.This is a common "reset" procedure for digital electronics which tend to lock up.Welcome to modern everything back in.Digital is almost anything which can be programmed and a few other things such as your phone,video game consoles,modems,on and on.Whenever you have a problem of lock up or no power try doing this first.If this doesn't work,just comment here and I will get an autolink and reply ASAP.
Good luck,Greg
Nov 18, 2010 | Sakar Talking Caller-ID Speaker Phone
Please ..need to know how to get other call on call waiting.. cordless phone 5.8
Adding call waiting as a feature to your telephone can help you take calls that you are waiting for without having to stay off the phone until that important call comes in. With call waiting, you get a beep when you are on another call to let you know that another call is coming in. If you want to take the call, you follow the simple steps outlined in this article.
  1. ep 1 Order call waiting from your phone provider if you do not already have it. Cal waiting works best with caller ID features that give you the phone number and name of the person calling you. Phone numbers that have blocked numbers or use *67 to mask their caller ID will not show up on caller ID.
  2. Step 2 Take a call when your phone rings. While you are talking on the phone and hear a beep, you are receiving another phone call. Using your caller ID function, whether it's on your answering machine or on your handset for the telephone, see who is calling you. If you want to talk to them, quickly press your "talk" button to put the other call on hold or disconnect. Press "talk" again to take the incoming call.
  3. Step 3 Disregard the other phone call if you do not want to terminate the call you are on. The new call coming in may go to your answering machine. Or if you have the call back feature on your telephone, you can simply call *69. Your phone will dial the number of the person whose call you just missed.
  4. Step 4 Use call waiting as politely as you can. You might tell someone who you are talking to that you are expecting an important call and may have to terminate the call abruptly. Call waiting calls should be answered as quickly as you can. After four rings, most phone calls go right to the machine or people hang up. Promise to call your first caller back if you have to interrupt the call
Nov 15, 2009 | GE 25942GE2 Cordless Phone System
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Aug 16, 2009 | Uniden Cordless Phone
Panasonic KX-TG2357 talking caller ID
To turn Talking Caller ID on or off
You can turn Talking Caller ID on or off for the handset and base unit separately. If
this feature is off, the unit will not announce caller names. The factory preset is ON.
Handset Talking Caller ID feature
1 Press [MENU].
2 Scroll to “Talk Caller ID” by pressing [d]
or [B], then press Select.
3 Select “Off” or “On” by pressing [d] or [B].
4 Press Save, then press [OFF].
Also Refer To Page 31 Of Your Owners Manual.
If You Do Not Have The Owners Manual It Can Be Downloaded Here.
Thank You For Using
Oct 10, 2008 | Panasonic KX-TG2357 Cordless Phone
(talking caller ID?)
The KX-T7633 phone (the model you selected) does not have that feature directly. However, the automated attendant can make those announcements for numbers you enter and prerecord names for, both on a system wide basis and within your mailbox.
In addition, the system can work with "talking caller ID boxes" if they are plugged into an SLC port with the Caller ID option. This works, but is not something many installers are even aware of.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Apr 07, 2008 | Panasonic KX-T7633 Corded Phone
Mar 15, 2008 | Panasonic KX-TG6052B Phone
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
ID volume
press volume on bottom of phone twice
Sep 09, 2007 | Innovage 1604007 Corded Phone
Panasonic KX-TG6700 Cordless Phone Logo
21 people viewed this question
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
