Question about Logitech 250 Headset
Annoying Static My NEW 250 headset has this constant static that interferes with the sound. It also messes with the microphone as I discovered in Team Fortress 2. I tried seeing if the headset works on another computer and it most certainly does. Anyone know whats up?
  • 1 more comment
  • BMLM Jan 02, 2008
    The static occurs all the time. Not just in game.
  • Anonymous Jan 15, 2008
    my headset dose the same thing its only started just resently
  • Anonymous Dec 22, 2008
    i have this problem and im getting sort of mad i was playin GMOD and all of a sudden it made static it may have been bumped hard though because that makes it change....
Thats crazy, I use the same headset and mine started acting up yesterday while playing TF2. It might have something to do with the game!
Posted on Jan 01, 2008
How do I get rid of the static sound in my 4PR908?
There causes varies from types of headset to another. In respect of a wireless headset, the static sound is caused by interference. Whereas in a cord headset, a loose wire somewhere in your headset or cord is responsible for the static sound or crackle. It might also emanate from the mic in respect of a one calling, or from the ear-piece.
The solution with a wireless headset is to move away from any device e.g computer which might have cause the static sound. Resetting the wireless headset is also a solution measure.
In the case of a cord headset; Get the cord wiggled at the plug and at the headset; and then move the mic to locate the loose connection. Where the problem occurs, loop the wire, taping it down at the point. soldering the affected wire is best than taping.
Finally, if the static sound persist;which it should not after all the treatments; check on the volume of the device. Reduction of the device volume can go a long way to bringing the longed solution. Similar problem occured with my headset;and was solved via the same recommended possibility.
Jan 30, 2015 | Wireless Gear 4PR908 Bluetooth v2.0 EDR...
Cordless phone static
It may be interference from an electrical appliance, try turning appliances off one at a time to see which is faulty, ensure home unit is far away from other appliances
Aug 09, 2014 | Vtech 107944 Digital Cordless Telephone...
Crackling static in sound
reduce the volume of the microphone
Mar 25, 2014 | HP ProBook 5310m (FM997UT) PC Notebook
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
Weak audio static uc2-ub handheld
Sounds like either local interference or it needs to go to Shure for repair. Can you try it in another location maybe 10 miles or further away from the present location. If it operates in the MHz band you need to replace it, it is illegel to use that band in the US..
Mar 13, 2012 | Shure Beta 87A Professional Microphone
Static problem
Try using a headset or lower the volume.
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Apr 11, 2009 | A4tech Viewcam PK335 Webcam
Webcam audio problem
Second reason is, if you are using a laptop and have added an external microphone and have a built-in mike, between the two it will cause distortion and static.
Mar 23, 2009 | Microsoft Lifecam 6000 Webcam
Speaker interference
Jun 23, 2008 | Microsoft LifeCam NX-6000 Webcam
Constant static and interference
FIRST YOU MUST DETERMINE IF THERE IS STATIC ON YOUR PHONE LINE. EVEN WITH DSL THERE CAN BE STATIC EVEN IF THE INTERNET IS WORKING. IF YOU HAVE A CORDED PHONE TAKE IT OUT TO THE PHONE INTERFACE BOX AND OPEN THE BOX / THERE SHOULD BE A PLACE YOU CAN UNPLUG YOUR WIRING FROM THE PHONE COMPANY. PLUG YOUR PHONE INTO WHERE YOU UNPLUGGED THE WIRING AND SEE IF YOU HAVE STATIC THERE. IF YOU STILL HEAR STATIC IT IS THE PHONE COMPANY'S PROBLEM.
SOMETIMES UNPLUGGING FROM BOTH THE PHONE LINE AND THE POWER SOURCE AND REMOVING THE BATTERIES WILL CORRECT SOME PROBLEMS. FOR SECOND PHONES ON A SYSTEM THEY MUST BE REGISTERED TO THE BASE. ONCE IT IS REGISTERED IT SHOULD SHOW A NUMBER IN CORNER OF SCREEN (2)
THE MANUAL SHOULD TELL YOU HOW TO REGISTER SETS. IF YOU HAVE LOST YOUR MANUAL SEE IF YOU CAN DOWNLOAD ONE FROM THE WEB SITE OR CALL VTECH 1-800-595-9511
Dec 05, 2007 | Vtech 5.8GHz Analog Cordless Phone
How do i get rid of this annoying static?
Static is caused by one a weak signal and two a defective circuit board in the phone.
Apr 08, 2017 | Sony Ericsson Z520a Headset Headset
Logitech 250 Headset Logo
313 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
