Dayton gas heater mod 3E404
Fan run all the time ...will not light burner
This is an easily fixed problem. There are two thermistor switches on Dayton furnaces. One controls the fan motor run function and the heater valve on/off function. The other called a blocked vent switch (located in the top front of the heater) stops the gas valve from opening in the event the
vent is plugged. However, if the furnace was totally shut down for the summer and is now being fired up for winter, the block vent switch has to be reset. The switch has a reset button on it, push it and it should solve your problem. Also, check to make sure the fan run thermistor is clean and does not have debris around it as that acts a insulator for heat to keep the fan run function on.
Posted on Nov 26, 2008
  • Gary Harper Oct 07, 2012
    Were is the switch located at
It sounds like you have a couple of problems.
1. fan run all the time. I am sure is your fan delay module.
2. will not light. That would be the gas valve.
call they can help
Posted on Mar 02, 2008
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan:
Dec 21, 2015 | Dayton Heating & Cooling
I have a hanging Dayton in garage pilot lights fine furnace fires up runs 6or7 min. then burner and pilot go out
Does unit fan come on ??? Is flue clear as most units have a safety klixon if exhaust not venting properly.
Nov 24, 2012 | Dayton Gas Furnace Heater
Dayton gas furnace model 3e385 works and lights but as soon as fan comes on the unit shuts off and lights again wondering what was wrong
Check heat exchanger for cracks or holes which will cause the fan to blow out the flames. The flame sensor on the pilot or burners has to be in constant contact with flame to operate normally. If the flame is put out by a cracked exchanger the exchanger or furnace needs to be replaced.
Nov 22, 2011 | Dayton Gas Furnace Heater
Pilot stays lite but fan comes on without burners lighting
On older systems the fan is controlled by a time delay relay which will turn of the blower after a preset time when a call for heat is present regardless if there is a burner function or not.
Need to check why the main gas valve is not energizing, there are to many configurations for a complete diagnostic without further info, Model, Brand etc.
Feb 25, 2011 | Dayton Gas Furnace Heater
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
Carrier super saver furnace keeps going on and off
Sounds like the flame sensor is dirty or bad. This sits in the burner flame when the burners are running. This usually has a single white wire connected to the back of it.
Jan 03, 2010 | Dayton Gas Furnace Heater
I have a dayton heater and need to switch it to propane from natural gas, i cant find orfice or the spring anywhere to buy them is there somewhere to buy these parts? the model nuber is M-3e404, and the...
Call this number 1-800-323-0620 That is the Grainger Parts line. The Dayton units are all made for Grainger.
They will be able to tell you (1) if the unit can be converted.
(2) If the parts are available to convert that unit.
(3) You will also be able to order the parts directly from them if they are available.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Dec 08, 2009 | Dayton Gas Furnace Heater
Dayton gas furnace
try cleaning the flame sensor and the burner , check out the pressure switch might be blocked in the tubes
Dec 07, 2008 | Dayton Gas Furnace Heater
I have a Dayton 4LX55 tubular heater in my shop that won't light
Check your thermostat and see that it’s wired correctly, it should be as followed for this particular unit; R-W-G from the thermostat terminal, and R-W1-G on the units terminal strip. Also check and make sure you have gas to the unit and make sure the switch to the gas valve is in the “ON” position. If all of the above is correct and working, you could have a bad igniter, or a have a flame rollout, or high limit switch tripped.
Hope this helps
Dec 03, 2008 | Dayton Heating & Cooling
I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Nov 20, 2008 | Dayton (3E379) Heater
Heating & Cooling Logo
514 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
