Best Solution
posted on Nov 06, 2009
Rank: Wiz
Rating: 99%, 15 votes
sm_schedule, the side bolts you removed were, in fact, the brush holder caps, and if you remove the brushes, you cut off the power to the electric motor (armature). I suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and make sure the concave contact face of the brushes are resting completely on the armature. If you've turned a brush 90 degrees too much, it wont' seat properly. As far as adjusting the mixer head so that it doesn?t droop, this should be pretty easy to fix if you?ve got a small blade screw driver and a small hex driver (or jewelers screw driver). First, do you still have the KSM90 Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use KSM90P) and select one of the files that appear under Parts List. Turn to page 4 - Case, Gearing and Planetary unit, which shows the exploded view diagram and locate Illus. Nos. 29 & 30. Page 5 lists the parts as Adjusting Screw and Set Screw respectively. What?s probably happened is that over 12 years of operation, the vibrations from your mixer has caused the set screw to loosen and drop, hence the lower mixer head. Both screws will need to be ?adjusted? to move the head back to its original position. Now the problem is removing the head from its pedestal. Turn to page 8 and gently remove Illus. No. 7, Hinge Pin, with a hammer and pin driver. With the hinge pin removed the mixer head and pedestal can be separated and you should have access to adjusting and set screws. I would inspect them for wear and tear, and replace them, if you deem appropriate. It may take a few trial reassemblies to get the mixer head back to the original factory position, but once there, everything should be OK. I hope this helps! Howard, Burke, VA
