Question about Dryers
No heat from Danby dryer
We have a Danby dryer that suddenly has no heat. It has power, goes through the programs fine and spins, just no heat. Help!! :(
  • austinamigo Dec 31, 2007
    Tried the breakers, no luck
    President:
  • 1,314 Answers
Try resettig your breaker turn it off then on see if that helps
Posted on Dec 30, 2007
  • robert samples Dec 31, 2007
    probably have a bad heating element try different heat settings if you get any heat then element is good thermostat bad but first you need to check the outlet for 220 volts drier will run on 110 but wont heat if you have 220 at outlet then check the cord where it attaches to the drier most of the time this is where we find the problems if you don't have a meter you can get them cheap at lowes or radio shack then reply and ill walk you through it make sure the leads on the meter have probes with long metal ends to reach in the outlet deep enough to reach the terminals
Bought my dryer bout 3 years ago it spins fine , goes on spins, just wont heat at all.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | Dryers
Danby dcd5505w clothes dryer is not heating
heatman101
Nov 21, 2010 | Danby DCD5505W Electric Dryer
Suddenly drier spins ans work as usual but does not heat up. therefore, clothes are not dried even after three hours of spin.
heatman101
Aug 29, 2010 | EuroTech EDC158 Electric Dryer
My danby dryer is not heating up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
stuu
Oct 03, 2009 | Danby DDW1805W Designer Series...
My Danby dryer dcd5505w hums but wont tumble. I opened it up and pushed it and it ran for a bit and stopped. I pushed it again and it ran for about 3 minutes before stopping. The motor is okay and so is...
the motor is most likely the cause. once it starts to hum, it's not spinning :( bad brushes inside. replace the motor or get new dryer, sorry :(
Joe
Aug 26, 2009 | Danby Dryers
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 07, 2009 | GE DVL223GB Gas Dryer
Horrible noise during fast spin
nail washer to floor or strong glue it to the floor
Dec 26, 2008 | Danby DWM5500W Front Load Washer
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Danby spin / washer
Danby DTT420 W
Mine just stopped working on gentle cycle and will only go fast in one direction on normal. Worked fine when I put it away.... :(
May 18, 2008 | Danby DTT420 Top Load Washer
Dryers Logo
114 people viewed this question
Top Dryers Experts
Marvin
Marvin
