Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Cuisinart coffee maker has a blinking on/off button and wont turn on or off or do anything else?
  • krbartee Jan 01, 2008
    is there a resest or what do i do with it now?
  • Anonymous Feb 04, 2008
    yes, I have the same problem. However, my coffemaker's "program" light will not shut off--and none of the other buttons will work.
    D. S., San Diego, CA
Where do I find the main power reset?
Posted on Jan 10, 2008
  • 45 Answers
The touch panel seems to have gone faulty.
Posted on Dec 30, 2007
  • Sunny Masc Jan 06, 2008
    on the touch panels, there is no reset button. The reset can only be for the main power. try the main power reset, if it does not reset then the touch panel has to be replaced.
2 Suggested Answers
  • 85 Answers
SOURCE: self clean light keeps blinking
Hello guindonlm,
I recently had this similar problem. Try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart DBG-500 has - -- on screen won't do anything
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke dwn - you wouldn't be upset if your $15 Mr. Coffee broke eveyr year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Dec 15, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisinart cod-4000 powers up no brew
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Dec 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
My cuisinart Grind and Brew is only making 4 cups of coffee. Can you help us to fix this? We've turned off the 1-4 cup button...but its still only brewing 4 cups, we have to hit brew again in order to get...
Another possible reason for backup - using paper/gold tone filter at same time. If not:
-Tha Mp3 Doctor
Nov 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Nov 15, 2008 | Cuisinart Coffeemakers
Cuisinart grind and brew's program light wont stop blinking
Could be electrical, but: Hold in the program set button for several seconds. Set it for some time. Press the program set button one more time. See if it resolves the issue.
-Tha Mp3 Doctor
Nov 03, 2008 | Cuisinart DGB-500 Coffee Maker
I can't turn off the grinder- sometimes it just starts up in the middle of the brew cycle- sometimes it wont even start- i have only had this machine GRIND& BREW coffee maker about 6 mo- is this...
-Tha Mp3 Doctor
Oct 08, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Grinder not working
-Tha Mp3 Doctor
Sep 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Machine shuts off after beans are ground & sometimes when pot is 1/4 full
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. Serial number is engraved onto the very bottom of the coffee maker - hard to read. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
-Tha Mp3 Doctor
PS: The DGB-550BK is better
Jul 17, 2007 | Cuisinart DGB-500 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
519 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
