Question about Mitsubishi VS-50501 50" Rear Projection Television
Mitsubishi VS-50501 - Black Screen
My Mitsubishi TV was working fine until today. Now when I turn it on, the screen is black with no sound. I unplug the tv so it can reset itself but that is not working. Any idea on what the problem(s) could be?
  • THOMAS12 Apr 30, 2008
    SOUND NO PICTURE
  • roserico May 23, 2008
    i have the same problem i tried to fix the volume with the remote but nothing
  • Mitsubishi Master
  • 8,617 Answers
Is the power light staying on? If so press imput and menu together for 5 seconds to see if the set will blink a 2 digit repeating code. If that doesnt work. Check for CRT coolant leaks on the boards. This seems to happen alot as do faulty capacitors. Coolant leaks will be located on the chassis directly under the tubes they can cause corrosion and prevent your set from starting especially in the VS models.
Posted on Jan 04, 2008
Model VS 50501A TV. Works fine for awhile then screen goes black
most likly its your lamp you just need to get a new one off the internet or you can bring it to a repair shop and they will be able to replace it for alittle bit more then the lamp itself will cost
Mar 14, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
No picture
Check the heater power supply. you can find it at the CRT cuircuit at the back of the Picture tube. labeled H1 and H2 check the resistor Bias or re-heat CRT socket.
Dec 19, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi vs 5075
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
MISTUBISHI VS-50501A - top 3/4 of screen displays ok, rest does not
Check the vertcle yoke pins for solder cracks. Check verticle output circuitry resistors and transistors. And also check for Coolant leaks from the CRTs this happens alot. Check capacitors for any signs of sweeling or heat as well.
Sep 15, 2007 | Mitsubishi VS-50501 50" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Televison & Video Logo
183 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
