Question about HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050 won't print - os X
This printer worked fine for a long time.  Then started having problems with it printing.  Removed printer from printer list and could not add it again so I uninstalled and reinstalled the drivers for the Mac OS 10.3.9.  Printer still will not print - the print job goes into the queue and then disappears without any errors and the job is not printed.  I can get the printer to print using the HP Utility software so I know there is communication between the computer and printer.  Any ideas?
  • Annie1962 Jan 28, 2008
    The Laserjet 3050 has never worked on my Mac 10.3. The print job goes into que and then transmits to the printer but the job won't print. In the que the job shows as printed. Any ideas?
  • Anonymous Mar 26, 2014
    Scanner and copier on RX680 works. When I try to print, it goes on and out of the queue and appears to be printing if I just look at the screen, but the document doesn't print! I have already reinstalled the driver several times.
    President:
  • 4,402 Answers
Power off printer, disconnect all leads such as USB, network, etc and power on again.
Does it power on to the normal state?
Are there any messages on the control panel or light patterns (eg off, on, flashing etc)?
Posted on Jan 10, 2008
Why do I get bleed through printing on page.
You didn't use HP ink and/or recycled paper is in your printer. Also check that dark/heavy ink is not selected on printer setup on the computer.
Jul 29, 2014 | HP LaserJet 3050 All-In-One Printer
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
My HP Laserjet 3050 frequently pauses when I try to print something like a PDF image. Other times, it just won't print it.
A PDF file is a "complicated" document, containing lots of "put some text starting at (X,Y) using font Z at W pixels high".
So, the software inside the printer takes some time for the printer's CPU to "compose" a complete page.
Apr 10, 2010 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Mar 12, 2009 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 3050 scan problem
You should go to HP.com and look for a TWAIN scanner driver the works for that printer in Vista.
Jun 14, 2008 | HP LaserJet 3050 All-In-One Printer
Hp 3050
What OS do you have XP or vista
if vista then go to hp.com and get the vista drivers..
May 31, 2008 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050, 2605dn, 1022n
One time un reinstall the all printer drivers Before u go to C:\WINDOWS\system32\spool\drivers\w32x86.then delete all folders and files
Apr 08, 2008 | HP LaserJet 3050 All-In-One Printer
Replacing Print Cartridge
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Problem while copying
mark on scan glass, clean glass slit in where original is fed for copying
Nov 07, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
456 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
