not completing cycle...beeping and flashing F error...clothes not rung out . If I press the pause button the door stays locked and machine shuts down ...I can however tell it to do a drain and spin and it will complete the cycle perfectly
Washer has a loud thumping noise on high speed spin, checked behind rubber gasket and the plastic...
(More)
Washer has a loud thumping noise on high speed spin, checked behind rubber gasket and the plastic fins are all broken. why and can I fix?
the rubber seal in the front became loose and the wire part came out - can i fix it? Replace the...
(More)
the rubber seal in the front became loose and the wire part came out - can i fix it? Replace the seal? fix to it? model 42844403
My kenmore HE3 kingsize front load washer will not drain the water out. It will show an F2 error...
(More)
My kenmore HE3 kingsize front load washer will not drain the water out. It will show an F2 error code, then go to drain and spin, but not drain out. Each time, try it, more water goes into the tub. Then, when I shut the washer off the last time (by pulling plug as washer won't let me shut it off), the washer door will not open. Of course my husband is hunting through Monday, and want to get the water and clothes from washer before that. Also, did wash a load of clothes just before this one and everything was fine. Thanks for any help. Deb
