Question about Linksys Wireless-G WRT54G Router (DSLSWRT54G)
LinksysWRT54GS V7 Wireless Router
I have a DSL modem with Cavalier. I wanted to connect my other desktop to this service, so I purchased this router. I followed the CD to the letter (I'm running Wiindows XP, SP2) on installation and connection. When I came to the part where they searched for the router, it said there was no router detected on the system. I kept retrying, but to no avail. Is there anything I can do to remedy this?
  • jmsz Dec 30, 2007
    my Toshiba laptop in dining room will not detect signal from WRT54G which is installed upstairs in my house upstairs. Up graded antennas were installed, laptop still won't connect. My house is old construction, metal lath plastered walls
  • 589 Answers
I've run into this dozens of times. With DSL, keep in mind the software on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer that has the software installed (verizon, etc) will be able to connect.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Posted on Jan 07, 2008
  • 205 Answers
So if I understand you, you have an ethernet cable running from your DSL modem to the Internet port on the back of the Linksys router and then an ethernet cable connecting one of your computers to one of the numbered ports on the router. Is that correct?
If the above is correct, using the computer that is hooked to the router via the cable, open Internet Explorer and type the following in the Address Bar:
http://192.168.1.1
The Username should be left blank and the default password is "admin" with no quotes.
See what happens when you try this and let me know. This may take a few steps to get going.
Posted on Dec 30, 2007
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Dec 27, 2011 | Computers & Internet
Is there a way to hook into my dsl internet to get wifi
Does your DSL not have a wireless router? If not, you can certainly get one for cheap...walmart has Belkin/Netgear/ASUS wireless routers for about $40...the instructions are pretty straight-forward. It's a cheap and easy. let me know if you need assistance.
http://www.walmart.com/search/search-ng.do?search_constraint=0&ic=48_0&search_query=Router
Jul 19, 2010 | Dell Dimension 4700 PC Desktop
How a conect to internet
METHOD 1 - Using Internet connection using DSL or cable connection.
1st. If you wish to connect to the Internet with a LAN cable or a wirelessly and if your computer doesn't have a LAN card or wireless LAN card you need to purchase a LAN card (to configure the wireless router) and if you want a wireless connection you will also need to purchase a wireless LAN card.
2nd. You need to select an Internet Service Provider in your area with a plan and cost to suit your requirements.
3rd. You need to decide what type of broadband connection you need, DSL or cable modem with or without a built-in wireless router, the Internet Service Provider can assist you with this.
5th. The Internet Service Provider can supply these items or advise you what make and model to purchase. They will also provide information on how to connect and setup your Internet connection.
METHOD 2 - Using USB wireless adapter that plugs into the laptop's USB port. It doesn't need a wireless router or a cable or DSL modem.
This is used mostly on laptop computers which allows Internet access anywhere the Internet Service Provide has a wireless transmitter. It uses the G3 mobile system.
This type of service usually costs more and again you need to select an Internet Service Provider that can provide the wireless coverage, the plan and costs that suit your requirements.
Installation and setting up information is supplied by the ISP.
Jul 31, 2009 | Computers & Internet
D-link DGL-4500 is not accessing my dsl modem
make sure the dsl modem is in bridge mode. you do this by connecting directly to the modem then accessing modem configuration page. after doing this connect the way everything was before. now go to router admin page, then setup tab at the top, then choose internet, manual setup. in the place where its says my internet connection is select PPPoE. then put in your dsl username, password and etc. save settings. this should fix the problem
Apr 20, 2009 | D-Link DGL-4500 Wireless Router
How do I connect a MaxG wireless router into a SmartAX MT880 DSL modem
  • Connect cable from router to computer ...
  • Connect cable from router (internet port) to the modem ....
  • U will be able to go online ....
  • And after it is done ...u can do the wireless settings ....
  • then connect to network and u will be perfectly able to go online ....
Oct 24, 2008 | U.S. Robotics (USR8054) Router
I have a netgear wireless router which I need to configure. Part of the process requires me to connect the router to the modem. However the modem uses a USB connection. How do I connect it to the router?
I would check you have the right router, as DSL and cable use different types routers, if you are on a DSL connection my advice would be to return the router and purchase a modem/router and do away with your modem, if you are on cable modem, you have bought a DSL modem as they have no connection for a modem.
Oct 03, 2008 | Computers & Internet
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
I have a DSL router provided by frontier. I am trying to make my desktop wireless. I believe that my DSL router functions as a modem also. I purchased a Linksys wireless broadband router. I can't not...
Your router should just be that, a router. Your connection is probably like fibernet the modem is actually on the outside of the house. This may help or may not but I have a linksys wired router that works very well but you have to go to their website in order to set up the router. You may need to look through your papers and find the web address to connect to the right site.
Apr 17, 2008 | Computers & Internet
Internet promplems
for dial up simply a modem .... on laptops if you do not have a builtin modem you can purchase a pc-card modem that goes into your pcmcia slot ... for highspeed either a ethernet (same option as modem) but almost all modern laptops have a built in ethernet ... or usb ... also I highly recommend a router if you are going highspeed ... even if you only have one computer ... a router will protect your system because it provides a NAT firewall. If you go with a router make sure to set up the internet connection on the router do not tunnel through the router with a PPPoE connection
Mar 30, 2008 | Computers & Internet
Installing wireless G router
Yes, you do need a modem (DSL, Cable). This router does not function as a modem.
Oct 01, 2007 | Belkin (F6D3230-4) Router (F6D32304)
Linksys Wireless-G WRT54G Router (DSLSWRT54G) Logo
56 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
