Question about Sony PlayStation 2 (PS2) Console
Delay i have a delay either in sound or video, it is hooked up to a new lcd tv with s-video adaptor. i have a older playstation 2. can you help?
    Problem Solver:
  • 18 Answers
This may be caused by the connection or the age of the PS2, try a regualar AV Cable/Scart Cable and see if that works, if not, contact SONY.
Posted on Dec 31, 2007
Samsung UN40ES6100 HDTV has a sound delay that I can't get rid of
My LCD panel is broekn? is it work to replace the LCD panel ?\
The Replacement LCD panel code is BN95-00604A
How to do the LCD panel repleacment
Jun 12, 2012 | Samsung UN40ES6100 40 Inch 1080p Smart TV...
Had someone from Best buy set up my new Sony bravia 47 in LCD TV. He said I should not use my slightly older Bose Cinemate digital home theater speaker system with the newer TV because the speaker system...
Hello,thats a first and he is completely wrong.The sound will arrive at the stereo at the same time it arrives at the cable box or the tv,depending on what source the stereo is hooked up to.Without going too in depth he is referring to center channel delay which is a feature in some home theaters created to induce a delay when its required, most notably when a projector is used.
Feb 20, 2011 | Bose Cinemate Digital Home Theater System...
I was recently given an older 32" TV. I want to
Radioshack always have something for problems like this.
You need an RF Modulator..
It's very simple and self explanatory.
Jan 19, 2011 | Sony Playstation 3 (PS3) Console
Lag between PS3 and LCD TV
How is your PS3 connected to the TV? only HDMI?
I can help troubleshoot but tough forum to do it.
generally, go over PS3 set up and select appropriate display. Video thought HDMI and sound though optical to receiver/amp should be your ideal configuration unless everything is all sony then you can see if pass thru works with your receiver, which is where I think you are have delays.
Tough though not much info.
Mar 28, 2010 | Video Game Consoles & Games
Cant hook ps3 up
Can you explain your problem with a little more detail?
Have you already tried a manual video reset?
Are you using A / V cables?
Feb 28, 2009 | Sony Playstation 3 (PS3) Console
No color for ps2
Check the AV wires. I've pulled a mistake before where I plugged the Video wire into one port (say AV2) and the audio into (say AV3). Drove myself nuts trying to figure out what was happening (video but no audio on AV2, and audio but no video on AV3). Eventually I fixed it and it worked.
Make sure the wires are in the right AV ports. If that's not the problem, then it's probably an issue with the TV. If that's the case, hook up a GameCube or a similar console (provided you have one) in the same ports as the PS2. If it does the same thing as the PS2, then it's probably the TV's fault. If it works fine it's most likely the PS2's fault.
Nov 24, 2008 | Sony PlayStation 2 Slimline Console
I need help
all you have to do for your ps2 is plug in the yellow red and white slot onto your t.v. from the ps2 wire. then make sure that you put it on the right video
Jul 04, 2008 | Sony PlayStation Portable (PSP) Console
Hooking up PS2 to Component hookups on 37" LG LCD
make sure the input is turned on in the menu. Sometimes they get locked out.
Dec 30, 2007 | LG 37LP1D 37 in. LCD Television
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Sony PlayStation 2 (PS2) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
