Canon imageCLASS MF6530 Monochrome Laser Copier Printer
Problem for Canon imageCLASS MF6530 Monochrome Laser Copier Printer
My Canon MF6530 keeps flashing
By shelia_lebea on Oct 21, 2009
My Canon MF6530 keeps flashing "clean platen glass" even though I've cleaned it several times. How do I correct?
Comments:
Oct 21, 2009
- Thank...found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Oct 21, 2009
Oct 21, 2009
- Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , in the search window enter "clean platen glass", now select item "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Solution #1
posted on Oct 22, 2009
Somewhat Helpful)
cnelli1
Rank: Wiz  Canon Expert
Rating: 78%, 13 votes
You have to take out the glass platten, clean it on both sides.
Then clean the top of the contact sensor (scanner) lightly with alcohol.
Good luck
Was this helpful?
Yes
No
Popular Solutions for Canon imageCLASS MF6530
Questions and Unsolved Problems for Canon imageCLASS MF6530
Do you recommend Canon imageCLASS MF6530 Monochrome Laser Copier Printer?
Answer
Answer
Why is my pages printing blank from both copier and PC documents
Answer
Used card stock in manual feeder. Paper jammed. Removed paper. Now no print on copies. Toner ok.... (More)
Answer
When I make a copy with our machine, it goes through all the motions, but nothing comes out on the... (More)
Answer
Canon ImageClass MF6580 prints blank pages in copier mode and pc mode. Changed multiple 106... (More)
Answer
The printer keeps pulling paper as to print double sided. I have changed to print on one side and it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon imageCLASS MF6530...:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
