few things to check , if its a dual voltage model check that its set for correct voltage ( if your on a 110v supply and the heaters set to 240v , then the fan will spin too slow and cause the over temp stat to activate ) replace the thermocouple ( a metal tube that sticks into the flame path ( usually has a brass/copper tube running out from it to the over temp stat and down to the gas relay valve , be very gentle whilst replacing this as there is a fibre washer /insulator on the end and it can easily be damaged by over tighting (
I plug my ready heater in and it will run for a few minutes and it will start to smell like fuel and...
(More)
I plug my ready heater in and it will run for a few minutes and it will start to smell like fuel and shut off
I have a rllp35a propane reddy heater that will run as long as I hold the automatic control button...
(More)
I have a rllp35a propane reddy heater that will run as long as I hold the automatic control button in,let it go and it shuts off, is this a problem with thermocouple or thermal switch?
