The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
when switching on the dryer it does not spin just same sound as if the cycle has finished.i have...
(More)
when switching on the dryer it does not spin just same sound as if the cycle has finished.i have opened top of dryer and switched on and the on light goes on and off.wondered whether it was relay circuit whether it has burnt out.
my water full light comes on after a short period and stops machine leave for 30 mins or so and it...
(More)
MY WATER FULL LIGHT COMES ON AFTER A SHORT PERIOD AND STOPS MACHINE LEAVE FOR 30 MINS OR SO AND IT GOES AGAIN FOR ANOTHER SHORT TIME
when i turn on my candy condenser dryer it starts but will not stay on unless you keep finger on the...
(More)
when i turn on my candy condenser dryer it starts but will not stay on unless you keep finger on the button
