If the engine dies shortly after start. Squeeze the spray wand trigger to release pressure on the unit. When restarting let the engine run for a few min(2-3 no more) to warm up, the unloader valve on the pump should keep pressure to a minimum. If the engine stalls or will not run you need to check your carburetor and clean it. BECAREFUL as FUEL is FLAMMABLE and there are small parts in the carb float bowl that like to get lost. A rebuild kit for most carbs is less than $8USD and a can of spray carb cleaner about$2-3. Install a fuel cut off valve($6) to keep the carb from gumming up again. Shut off the fuel when not in use or for periods of prolonged storage. Take a picture of the carb on the engine(my memory is bad) and during disassembly to assure you get it back together properly. The idle screw should be turned in(to the right)till it seats lightly then backed out 1&1/2 to 2&1/2 turns to start with. After starting the engine adjust for good idle and running buy turning in or out to attain the best idle. If this is helpful, Please leave Feedback. Thanks, SnugglePants
Testimonial: "Thanks! "
