Question about Power Acoustik PS2-1600 Car Audio Amplifier
Power acoustik ps2-1600 blowing fuses
Hello, i just purchased a power acoustik ps2 1600 power amp from a friedn really cheap because he said it stayed in protection mode all the time since he bought it new. but he couldn't return it because he lost the reciept. anyway i hook it all up and turn the radio on which in turn cuts the remote wire on then in about 1 second all 3 fuses blow. i took the amp apart and didn't see anything burnt on the board or anything obviously wrong with it. i would appretiate any and all help. thanks Jamie
  • Anonymous Aug 04, 2008
    no prende cuando lo conecto a mi regulated dc power supply
  • 631 Answers
Generally, this would indicate that the output transistors are shorted (which is generally a relatively simple repair). But an amplifier that never worked properly could indicate that it has a manufacturing defect. Sometimes, it's as simple as a bridged solder connection. Other times, it could be due to a missing component (which may be more difficult to repair).
The first thing you need to do is to check the output transistors. They will typically be the larger devices clamped to the heatsink. If you find any that are shorted (~0 ohms) between legs 2 and 3, you have at least one shorted transistor.
Before you do anything inside the amp, remove it from the power source and read the following page:
Basic Amp Repair
Posted on Dec 30, 2007
What type of fuse should I use I have a 1000watt power acoustik
Ohm's Law says watts / volts = amps, so 1000/12 is 83+change -- damn! I hope you have a big, phat alternator! So fuses have to be rated somewhat higher than device load, you need a 90 amp or 100 amp fuse -- what style I couldn't even begin to guess, normal automotive fuses don't go that high.
If this is a new install, make sure your power wires are heavy enough to handle the load. A fuse's job is to blow before the wiring catches fire. The longer the wire is, the thicker it must be. Electrical fire is a catastrophe so make sure your wiring is adequate -- I know it's hard to believe but the power wire is actually more important than the speaker wire!
Jun 28, 2015 | Power Acoustik Car Audio & Video
My power acoustik bamf 2200 amp keeps blowing its fuses, why?
another couple of things is a bad ground wire. a sub going bad( causing a different ohm load then before) ive run into a bad fuse link in the amp before as well
Aug 04, 2014 | Power Acoustik BAMF2000/1D Car Amp
Fuses amp
Yes, your amplifier needs the amout of fuses as there are fuse ports.
In case something were to go wrong it would blow the fuses instead of your amp and subs and burning your wire harness up..
I hope this helps.
May 12, 2013 | Power Acoustik A1800DB Car Audio Amplifier
It turns on then blows all the fuses
Hello
Check for any short circuit with wiring of the amp. If there is no such fault, surely your amp need service. It has some internal shorted components. This work is really a skilled one, and can only be done by any experienced service personal only. OK.
Jan 17, 2012 | Power Acoustik Car Audio & Video
When I connect my 2nd sub, the amp blows fuses. Each sub plays fine individually.
Does your fuse blow when volume turned up, or does it blow straight away when turned on? What watt is your subs and amp?
Mar 04, 2011 | Power Acoustik OVN2-800 Car Amp
It keeps blowing a fuse
Generally, if you are using the manufactures fuse rating you can use a slightly higher rating and it will resolve the blowing fuses. Fuses supply resistance, if there isn't enough resistance you'll fry the system board in the amplifier. But if you have 25 amp fuses installed, install 30 amp, if you have 30 install 35 amp, 35 install 40. Anything higher will damage the amp.
Hope this helps.
A rare chance, something may be internally wrong with the amp and shorting it out which will blow the fuse.
Use the incorrect wiring of subs to the amp, you'll blow fuses and damage the amp from it turning off consistently. The amp should be running at 2 ohm stereo stable or 4 ohm mono stable.
Very few amps are designed to run at 1 ohm or less. Not to mention the subs can't handle it.
Jul 28, 2010 | Power Acoustik TS980-2 2 Channel 980W...
Everytime i plug my amp up it blows the fuse what is wrong with it
Power and ground are touching. Either at the terminals or inside the amp itself.
Apr 04, 2010 | Power Acoustik LT-980/2 Car Audio...
How do you fix a blown fuse circuit in a lt1440 power acoustik amp
Just replace the blown fuse with one of the same amp rating... If the fuse keeps blowing you'll wanna recheck your wiring and make sure you don't have a short somewhere.
Sep 20, 2009 | Power Acoustik LT-1440/2 Car Audio...
Amp keeps blowin the two 30amp fuses on the amp.
Make sure that the speaker wires are wired correct at both the amp and the speakers......otherwise it sounds like the typical death of a power acoustik amp (great amps, but prone to a premature death)
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 29, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Beer Spilled on my Power Acoustik PS2-820 Amp
Hi , now that you have the amp apart , just check the underside of the printed circuit board and check for any corrosion ,rub it with a soft brush . then try connecting without speakers . see if it still blows fuse, if it does then there is a likelihood that your mosfets / outputs may have shorted the first time you reconnected it . Good luck
Mar 21, 2007 | Power Acoustik PS2-820 Car Audio Amplifier
Power Acoustik PS2-1600 Car Audio Amplifier Logo
201 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
