Pin number or password. the password for the router for administration is admin and admin.... for security you may wish to change them. the pin number is likely for connecting to a secure network. it may actually be on a label on your router or you need to sign into your router to obtain it. first you need to hook into the router with a network cable from your computer to the router. open a web browser and type 192.168.1.1 the hopefully the default password wasn't changed (or you know it) once you have signed in find the tab for wireless security. your code/pin should be in the second tab of the submenu
Step 1:
Flip the device over.
Step 2:
You should find the model number on the sticker underneath the device. See the image below.
NOTE: Take note of the exact model number and version of your Linksys device. In this example, the model number of the device is WRT54G v5.
Step 3:
Check the serial number which is located right underneath the model number.
NOTE: The
images may vary depending on the model number of your Linksys product.
If there is no version number beside the model number it means the
device is a version 1.
you get it number?
then try again connet with it and enter the pin code same like you get from router
<click here for instruction to setup your router>
