Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Canon multipass mp390
Hi; guys
I replaced my waste pad because it says it was full. I took it apart myself and change the pad. But now when I plugged it back in it comes up with that I have the wrong cartridge in it. So how can I reset this.
thanks dave
  • 52 Answers
Hi i am a certified Canon repair tech for this printer. what it sounds like is that the ribbon cable that go from the carridge unit to the main board are plugged in to the wrong connector. check the connectors and try to match up by size. hope this helps.
Posted on Jan 05, 2008
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Waste ink tank near full
Go about half way down this page and it shows you how to fix this problem.
It will require you to open up the printer to access the "waste tank" which is actually a thick felt pad.
Oct 14, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Canon multipass mp390 inkwell is full
You have to remove the entire printer engine and replace the ink absorber pad, you have to s, After that you have to go into diagnostic mode to reset the ink absorber level
Jun 18, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Message "wasted ink tank near full" on Canon Multipass F80
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Canon Multipass390 Waste Ink Tank near full
Have a look here
http://resetters.blogspot.com/2009/04/reset-waste-ink-tank-canon-mp390-and.html
Apr 29, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Waste ink near full error
Canon's a little shady when it comes to this, since any waste ink pad I've seen never has been more than 30-40% full. You can reset that status without cleaning the waste ink out and the printer should return to normal.
1) On the printer, press Additional Functions, Scan, Copy, Scan. This will put you in service mode.
2) Select Test mode at the bottom
3) Select #8 Printer Test, wait for more options. It should say 8-2 or 8-3; push the + or - button until it says 8-3 then hit Select. The menu will now say EEPRON Clear
4) Select Ink count which is option (0) and press set
5) Press Stop/Reset, then the power button and wait for it to restart.
I hope this helps!
Apr 15, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Waste ink near full message
Take paper towels and absorb the excess ink. Make sure that the electricial contact  that tell it is full are clean.
Dec 27, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Message code on cannon copier
You need to have the waste ink absorbers replaced, the cost of the absorbers should be around $20.00 and service is usually around 50.00. That is a very messy job, you must disassemble printer removed used/ waste ink pads in the bottom of machine reset ink counters and the reassemble printer.
Oct 24, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MP390 Waste Ink Near Full message
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
Sep 11, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Alarm light flashing
1) Printer on, press Additional Functions, Scan, Copy, Scan.
Now you should be in service mode; from there to waste ink tank reset
2) Select Test Mode, which is the last available selection
3) Select #8 Printer Test, it will do some cleaning, then it will come up with an other option; this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3! Push the + or - button until it says 8-3 then hit the select button
Then press Stop/Reset, Followed by the power button and then wait for it to restart.
Jan 08, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
150 people viewed this question
old marine
old marine
