Question about Panasonic PT-43LC14 43" Rear Projection HDTV
High def tv: We replaced the lamp unit, but don't know how to reset hour meter
We own a panasonic projection display tv. Model #PT-43LC14. No where in any of the instructions does it tell you how to reset the hour meter. Please help.
    Problem Solver:
Turn the TV power on the projection display or remote control.while pressing the volume button on the projection display hold down the PIP or split button on the remote control simultaneoulsy for more than 5 seconds.
Posted on Dec 31, 2007
How to reset the hour meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic PT-52LCX16
How do I reset the Panasonic PT-43LC14 projection TV's lamp hour meter
Go to "Service Mode Map" by pressing the "Volume down" button key on the front panel and "TV/Video" button key on the remote control at the same time and hold it for more than 5 seconds. You can now reset/change the value of lamp operation time.
Jdvillanueva
Sep 21, 2011 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-43LC14; I changed the lamp. I still get the lamp meter warning on the screen when I turn on the TV. How do I reset the lamp meter?
terayamam001,
Here is the procedure,
1. Turn on the television
2. Press the volume down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or " PIP" button on the remote.
This should solve your problem.
Thanks for using FixYa and for the great rating!!
hardrocko
Sep 12, 2010 | Panasonic PT-43LC14 43" Rear Projection...
How do i reset lamp hour meter
Turn On tv.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
This will reset lamp timer in Panasonic PT-43LC14
When the lamp time reset procedure is complete, the Lamp Time is Reset screen will appear.
Thanks.
Feb 05, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Need to reset hour lamp meter and held soen vol.-
Try holding down vol down on the TV and PIP/ play botton on the remote for 7 seconds. Their customer support should be able to help you too.
Oct 08, 2009 | Panasonic PT-43LC14 43" Rear Projection...
How do I reset the hour meter after I replace the lamp?
go to the setting s are and their may be a master reset in the menu options
Jan 22, 2009 | Panasonic PT-43LC14 43" Rear Projection...
How do I reset the lamp hour meter?
hiya 1st, remove the message , then if u hold the down volume button on THE TV and the split play button on ur remote for about 10 secs maybe longer u should get another message follow it, hope this helps.
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
185 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
