Question about Mitsubishi WS-65613 65" Rear Projection HDTV
Mitsubishi WS-65613 blinking green light
I'm not a real tech savvy kind of guy, can any of you guys help fix this w/o replacing anything? If there is any way. I just came back from a trip and found my TV like this, with blinking green LED light.
  • 3 more comments
  • Anonymous Apr 30, 2008
    blinking green light. Won't reset. Keeps blinking after unplugging and plugging back in.
  • veetaml Jul 24, 2008
    Yes, same problem, have to unplug tv for about a week, then it will come back on, last for about 2-4 weeks. Do I need to get a new part for the tv, or is there a solution, please help me
  • barcewski4 Oct 21, 2008
    Same problem here. what do I need to do? Thanks matt
  • Sir James Oct 29, 2008
    I have the same problem... flashing green light.. I love the tv except that it's so dang heavy when moving and that the plastic screen has a crack in the bottom... I have the mitsubishi medallion 1080 65inch i think.. model # ws65613
  • dschall44 Mar 27, 2009
    I have the same blinking green light problem & my tv won't turn on. I went to Radio Shack to get the 35V, 105 deg. C capacitors, but they only had 50V, 105 deg. C capacitors. Can anyone tell me if the 50V capacitors will work still?
Just wanted to say thanks to Chris on the info and pics he made available. Replaced capacitors with 35v from Radio Shack and trouble is fixed. Just want to add to make sure when you plug your DM card back, make sure is plugged in all the way. Once you replace the capacitors, the cover gets pushed just a little because they bigger than originals and it puts just a bit of pressure on cover not allowing it to line up just right. The way I did it; plugged the DM module 1st and then put the cover on it, but please make sure TV is off and unplugged.
Posted on Mar 11, 2008
    Genius:
  • 1,694 Answers
Requires DM Module repair.......go to this website for DIY..
www.chrisandnat.com/projects/blinkingtv/blink.htm ..........T.
Posted on Jan 29, 2008
    Genius:
  • 1,153 Answers
Try doing the self test by pressing input/device and menu for 5 sec. You should get an error code by blinks. see ctechnicians.com
Posted on Dec 30, 2007
Hello, my name is Tom. We have a mitsubishi ws-65613 and of course I have the green blinking light and nothing else happening. Tried to reset, unplug etc. Is it worth messing with or should I just bite...
The tv mitsubishi ws-65613 the DLP tv is big bulky and heavy.Many power issues problems and convergence problems over and over again.Buy a 46" LCD tv Samsung have great apps,friendly and a great picture.The priced is very fair too.
Oct 28, 2010 | Televison & Video
Can't turn on the TV. Green light keeps blinking.
You need to change the four capacitors C9B01,C9B02,C9B10,C9B11 all 1000 MFD 16 VOLT (on the DM board which is inside the metal shield standing upright on the left looking from the back of the set)The tops of the capacitors will look puffed out making them easy to find. This is your HD tuner digital board which is trying to reboot but can't - when the green light stops blinking after a minute,than you can power on your TV.
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
WS 65613 MITSUBISHI
your problem is in the power supply.check the regulator
Nov 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green light of death 1080 series
FIRST....did the TECH replace the CAPS in the DM module??
If he didn't....he's assuming the WORST case scenario and ESTIMATING for that....
In your situation, CALL a Mitsubishi Authorized Service center (God I hope this other guy wasn't one !)
I do Mitsubishi service....and it looks like the Mitsubishi Service website is presently undergoing maintenance this morning....
Otherwise, I would have priced out a NEW DM module and seen if that's what he was estimating.....
Oct 31, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Blinking green led light
I HAVE THE SAME PROBLEM BUT I HAVENT FOUND ANY GUIDE YET
Oct 16, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Green blinking light and tv would turn on
blinking light is an error code. Check the manual for it's meaning.
Aug 14, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65613 65 in. Rear
Bad DM module = replace or repair by skilled Mits tech only....
Research my solutions or comment,please.....
Oct 17, 2007 | Mitsubishi WS-65813 65" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
I can't turn on the TV.
I had the same problem. Unplugged it, reset it, everything. I went to work the next morning and left the light blinking, came home from work and it was off. I turned it on and so far, so good. Just give it some time to reset internally
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
604 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
