Question about Kenmore 30 in.32232 / 32239 / 32234 Gas Cooktop
Low flame from gas cooktop
My cooktop is new off of ebay none of the flames are very high especially the power burner. If i lift the disks the flame/gas flow seems strong. i do not have the manual.
  • Anonymous Mar 14, 2014
    cooktop works good but very low flame
  • Anonymous Mar 18, 2014
    flames don't burn high enough when on high.
  • 1,314 Answers
You can adjust the flames as follows pull a knob and look in the end of the brass peice you will see a small screw first you have to find a screw driver that will fit then with a pair of pliers hold the outer peice with the burner on and turn the screw one way rasies other lowers ideal adj is to turn buner all the way up then fast down if flame goes out to low keep working like that till flame is low but doesnt go out
Posted on Dec 30, 2007
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
When lighting one of the burners, the ingnition knob has to be held down over ten seconds for the flame to stay lit when the knob is released..
Lift the top of the Stove up.
Look for a Small line that goes to the Affected Burner.
At the end of that Line you will see a small Flathead Screw.
Turning That screw Clockwise Adjusts your Pilot Light for that Burner.
Be careful not to Adjust to High, it would just be a Waist of gas.
hope that helped.
May 20, 2009 | Gaggenau 11 in. VG 232 Gas Cooktop
Kitchenaid 30'' low flame output
It's wasn't the perfect solution but I removed all the burner caps and cleaned each one with a tooth brush. Then using a metal trussing pin, I poked through the flame holes to clean them. Noticed better flame output from both.
Mar 06, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
Feb 20, 2009 | GE 36 in. JGP628 Gas Cooktop
Flame burns too high t0 simmer
if you look closely, down the center of the knob ther should be an adjustment screw to lowert he flame
Jan 26, 2009 | Amana AKS3040 Gas Cooktop
GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
Creda 4 burner, converted to LP
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
Mar 13, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Kenmore 32099 Cooktop burners regulation
remove the burners and adjust the air ration with the slide at the bottom of the burner tube
Jul 25, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
Kenmore 30 in.32232 / 32239 / 32234 Gas Cooktop Logo
987 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
