Question about Sharp 32F640 32" TV
Sharp tv when i on the tv set fuse will busted
  • 4 Answers
Verify the diode bridge if it is not in the short circuit.and chemical capacitor, which is after the diode bridge and or demagnetiseur.
im sorry but my english is bad.
Posted on Feb 11, 2008
My Sharp Aquos LC 60 LE6400 Tv does not power up
Check first the fuse on power supply section if it is busted,if its not then the whole primary power supply is defective and should be replace
Nov 24, 2017 | Sharp Televison & Video
Sharp tv 20rs100s DEAD
If the televisions is DEAD first step to do the repair is,Check the AC cord if there's a continuity.If good check the fuse if busted or good.Then check the power supply from bridge type diode,regulator transistor and H-output.This checking can be done if you have a little knowledge in basic electronic.So if cant do repair and checking its better to call a technician.Thanks..
Aug 21, 2011 | Sharp Televison & Video
My 20 inches sharp t.v has no power.at the secondary section has no voltage at all and the led indicator is off
Check for busted fuse inside your TV, so you can switch it back on. So, open it up. Follow the power cord going inside your TV. The fuse is just near to it. Have it replaced, and have it carefully clean free from dust using 1/2 inch paint brush. Put the case back close, and plug it back to your outlet. Switch it on. Hope this
Jun 03, 2011 | Kitchen Ranges
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Power on TV went out and it will come back on.
help you, and thank you for casting your vote.
Sep 22, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
(no volume}
Good day.
Have you checked on the settings? Maybe the speaker function was turned off?
Also, the speaker migth got busted or the audio IC may be the root of this.
Please check.
chris
Mar 23, 2008 | Sharp 32J-S400 32" TV
Trouble in sharp t.v.
Good day.
Try to check if the fuse of your tv is busted. Also, try to look for any burnt parts.
chris
Nov 06, 2007 | Sharp 32C-240 32" TV
No power
You could have a bad high voltage transformer or problem with the power supply. If the set is over 6 years old, It would probably be better to replace it.
Jan 13, 2007 | Sharp 32F540 32" TV
Sharp 32F640 32" TV Logo
55 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
