Question about RCA P52937 52" Rear Projection Television
Rca ctc195 big screen tv trouble
Turned the tv off and went to bed, in the morning turned it back on, but no picture just snap snap snap pause and snap snap snap again. Do you know what the problem could be? Thank you, Lyndsy
  • 373 Answers
You are likely to have a high voltage transformer bad which is common problem for ctc 195 RCA If you look into the back of the tv it is the white square looking thing about 3 inches across by 3 inches with the large red wire coming from it and going back into the set. Must have original RCA part and must be unsoldered and solder in new one. Not to be done by the untrained. Average cost to come out and repair is $250 to $300. depending on the repairman (Note: the chassis is in a complete wooded chipcore box that will come out with quarter inch nutdriver and unplug two plugs at the top of the box The box or chassis can be taken to the repair shop leaving the screen at your home saving a service call. Hope this helps
Posted on Dec 30, 2007
My televisions picture is 3D like the colors have seperated
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from
May 08, 2010 | RCA R52WH73 Projection Television
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Set wont turn on, Beeps.
Try Resolder all of the Big Diodes around power supply.
Feb 18, 2009 | RCA P52960 52" Rear Projection Television
All the sudden pitcher is bowed and colors are sepertated
This is convergence. First read FL231 fuse problem in tips and trick section to see if this may be the problem
Jan 22, 2009 | RCA HD52W58 52" TV
Tv went out, made a pop sound and won't turn back on
Sounds like the flyback went out. Your set is a CTC195 you can get a replacement flyback for it at the following link. They also provide free instalation instructions and free on line tech support.
Apr 30, 2008 | RCA P56950 56" Rear Projection Television
Power problem on a RCA big screen TV
Even with the tv turned off, the power supply is still active.It's supplying voltages to the microcontroler, that's why each time you press the power button on remote the tv respond by turning on. First check the power cord to be well connected in the power-bar and if it's ok...well the power supply is defective and due to the high risk of electric shock i suggest you to call a technicien.
P.S. I respond here because I don't know why our chat session got disconected.
Feb 01, 2008 | Televison & Video
P46924 46 inch rca television
HEEELLP My P46924 chasis ptk195M1A won't power on, started few months ago, on and off by itseft, then changing channels by itself and then it won't turn on at all
Jan 23, 2008 | RCA P46924 46" Rear Projection Television
No power on RCA p60921
Replace the Power Supply switching transistor, If a CTC195 chassis it is the Q14101. Cost about $8.00 for part if you can do it.
Aug 04, 2007 | RCA P60921 60" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
199 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
