Question about Indesit W 123 Front Load Washer
Washer wont do spin cycle
My washer wont do the spin cycle at all. it will agitate but wont spin, I found the belt but dont know how to tighten it? or if that is even what I need to do? it doesnt seem too loose?
  • 1 more comment
  • kewlchic1031 Dec 30, 2007
    Thanks but I know the lid needs to be closed, I think its the belt, it sounds like it is trying to spin and there is a little bit of a burning smell, maybe the belt, but I just cant figure out how to tighten it>?????
    the model # is la712 I dont see anything that is in there, can I take the spinner thing off? thanks so much for your help (:
    it is a maytag, model # LA712 series 04 I am not sure how old that is, it was here with the house when I bought it two years ago. It seems in good shape though other than the spinning part (:
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 15, 2008
    President:
  • 1,294 Answers
Posted on Jan 26, 2008
    President:
  • 1,314 Answers
For safety most washer have a lid switch that the lid engages if that switch is bad wont spin lid must be closed for spin also
Posted on Dec 30, 2007
  • 2 more comments
  • robert samples Dec 30, 2007
    i need the model num and what brand most washers cant tightin belt look in the tub see if some thing like a nai or screw has fallen in hole jamming tum
    sorry tum is tub ill hang with you we will fix it
    that looks like the begining of a ser # is it a Whirlpool Frigidaire ge avanti bosh what brand can help but need to know
    we aint done yet my friend
My maytag washer model pav2300aww will not spin even though it agitates and drain but when it comes to the spin cycle it just kind of hums I looked at the bottom of the washer while it was in spin cycle...
Possible the revolution takes place on the top end of the pulley and belt but the centre stem of the agitator is not moving or it is slipping. It can be due to friction in the stem of the agitator due to clogging of dirt and the best option is to remove and clean the agitator.
Dec 11, 2012 | Washing Machines
Drum wont turn but the moter does
Hello Deanna - This particular issue could be caused by a variety of reasons. I would suggest trying the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer spins but will not agitate
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
Aug 14, 2012 | Frigidaire FEX831CS Top Load Stacked...
Washer is not agitating in whites and slowly in colors. What and how do we troubleshoot?
Aug 05, 2012 | Frigidaire FEX831CS Top Load Stacked...
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
Agitator will not spin on last cycle
try replacing cotter pin first.if that dont don't work try to get a used timer to try before buying a new one.hope this helps!!!!
Sep 07, 2009 | Whirlpool Washing Machines
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Amana NAV2330 Wont Agitate or Spin
i would assume that perhaps you did not wind hte belt correctly arround the legs of the pump and therefore are not putting the correct tension on hte pulley(remember to hook spring back up to tension idler?)
Dec 08, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore stacked W/D will not agitate during wash cycle
hi thanks for the question i dont know the model of your washer but i think yours is a direct drive no belt you have a motor drive coupling which is located between the motor and transmission replace that part thanks the appliance doctor
Mar 31, 2008 | Kenmore 98702 Stacked Washer/Dryer
Indesit W 123 Front Load Washer Logo
173 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
