Question about RCA HD61LPW175 61" Rear Projection HDTV
52 RCA DLP 1080P Television with NO picture and buttons flash
I went to turn the TV on in which nothing happened. The buttons on the TV started to flash for 5 seconds. After the flashing stops, the button stay lit for 5 seconds then they go off. Looks like the TV goes into standby mode.
RCA TV with ATC336 chassis. When I turn the set on the sound comes on and then the power light and other lights flash 5 times. Screen stays black and I can't change channels.
  • TVguy33 Jan 15, 2008
    Thanks for the email. I have the set working OK now. I did remove the light engine and clean the fans very well. The problem started after the projection light was replaced, not by me but by another dealer. All seems to be OK now. Thanks again.
    TVguy
  • Anonymous Mar 27, 2014
    The bulb in the TV works fine, but the TV will come on and then turn itself off and the blue light blinks 5 times. A few seconds after that the screen will come back on and do the same thing again.
Just replaced the lamp in my RCA 50" DLP because I didn't have a picture. Well it didn't work. After starting the TV up I got a picture for about 3 seconds and nothing after that. It appears as though the TV is powering up and then shutting down. I do have sound during all of this.
Posted on Apr 16, 2010
  • ColumbiaMo Apr 20, 2011
    Your tv is overheating and shutting down due to lack of cooling. Clean your fans and make sure theyre working properly
  • RCA Master
  • 8,617 Answers
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
  • Sonny Berry
    Sonny Berry Jan 15, 2008
    Glad to hear you got it working again.
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
Rca dlp hdtv widescreen - terrrible noise/flashing light
if its a dlp its most likely the color wheel that is causing the problem. Post your model number and i will assist you.Please respond to this same post.
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
Picture wont come on
No reset button, you may have a bad lamp. Look in you owners manual and which light is flashing it will tell you if the lamp is a possibility.
Mar 01, 2009 | RCA P52926 52" Rear Projection Television
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
No picture (fan& bulb do not come on) but there is sound
I have a RCA 52inch D52w136D, the power button blinks three times, but nothing happens no picture or sound
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
Help me please
You have bad capacitors 3 of them.cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v
Aug 09, 2008 | RCA D52W19 52" Rear Projection Television
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
i dont have a soultion for you but can tell of my experince with rca 52"dlp after having mine for six months did same thing sent it to the repair shop it stayed there for three months then they said they couldnt fix it tried to talk to rca cust serv reps who basicly said they didnt care after two more months i finaly got the store manager where i bought it to go to bat for me and they agreed to replace it but with a lower grade model and no warrenty as they said mine had expired even though it had been broken for eight months after three months the new one did the same thing i was told it was the light engine which cost 2 grand and were on forever backorder and id just get another tv before putting that much in that tv but it wont be another rca hope this helps now i have a 100lbs paper weight b4829@yahoo.com
Nov 09, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HD61LPW175 61" Rear Projection HDTV Logo
1,236 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
