Question about Kenmore 19606 Computerized Sewing Machine
19606 sewing machine
The dog feed switch does not work--material gets caught when sewing and the entire face plate with bobbin,etc needs to be taken apart to release material caught inside. the dog feet switch does not adjust the dog feed--like it is not attached. Upon opening the face switch the first time--the inner workings of metal appear to have been scratched like filed--my husband thinks the finish work was not completed after putting parts together--I think it looks like it has been refurbished. When I purchased it, there was no manual and half the accessories that were to accompany the machine--were missing, Saddly, I did not realize this until months later--I used my old machine, sine I could not get the new one to work properly & it was during the holidays. So now--I am stuck with a malfunctioning machine & am gravely disappointed.
    Problem Solver:
  • 6 Answers
Find a local dealer who sells Janome. This machine and most Kenmore's are made by Janome. However I know theyb will charge $80 or so to ven lok at it. I have this same machine also refurbished and no big issues as yet except buttonholer foot was broken when I got it. Am still awaiting a new one a month later.
Posted on Jun 09, 2009
Singer sew machine model 7256
First unplug, then check to see if there is thread or fabric caught in the feed dogs, bobbin case etc. If, gently pull on the object to release it.. Be really gentle, because you can bend your needle shaft. Take your time by taking out your bobbin, and oiling, brushing lint etc.
Jan 07, 2018 | Singer Sewing Machines
I only have a small amount of feed through the sewing claw, i mostly have to pull it through on my Toyota 2400, is this normal is is something wrong?
Unable to locate much information about your make/model machine.
If your machine has the capability of dropping the feed dogs for darning or free motion quilting, check that the feed dogs are in the up position for sewing. Also, verify that the stitch length is set to at least #2. Any shorter stitch selection will cause the machine to advance the fabric so slightly that it will nearly sew in place.
Some machines also have a pressure adjustment for the presser foot. If the fabric you are sewing is very fine, the feed dogs may have difficulty gripping the fabric to advance it through the machine. You can add body to the fabric by including a stabilizer when sewing the fabric, ie a wash-away stabilizer.
May 05, 2016 | Toyota Sewing Machines
Reverse button won't work. Anh trouble shooting tips?
This button simply reverses the action of the feed dogs of the machine. Remove the thread plate and all the mechanism (bobbin, bobbin holder, etc) you can in the bobbin area. This should give you a better view of the operation of the feed dogs. Rotate the machine with the hand wheel to see how it operates. Continue rotating the hand wheel and push the reverse button. See if you can spot what's preventing the feed mechanism from reversing its rotation. Hopefully it's as simple as material or thread buildup in the mechanism.
May 29, 2015 | Sewing Machines
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
Necchi 4595 feed dogs keep dropping
Tighten the screw under the plate near the feed dog
Sep 20, 2013 | Necchi 4595 Mechanical Sewing Machine
Problem with feed dogs and thread catching
Hello Emma,
Hope this helps.
When the feed dogs are lowered they will not go up with just the switch. Try this, move the feed dog switch to the up position, then turn the handwheel 1 complete rotation. Voila they should be up. Let me know if it is solved. Chris
May 30, 2017 | Janome Sewist 525S Mechanical Sewing...
Feeder dog is in reverse and thread won't feed through bobbin..
it would really be a good idea to have the machine serviced at a sewing
machine shop
May 05, 2012 | Sewing Machines
Material does not seem to be fed over plate thread keeps getting caught in bobbin
check and make sure that the feed dogs are in the up position there should be a switich in the back of the machine by the bobbin area
Jun 29, 2010 | Sewing Machines
Euro Pro 373om sewing machine
If you have checked the feed dog switch, best to take it to a sewing machine mechanic.
Jun 29, 2008 | Euro-Pro 373 Mechanical Sewing Machine
Kenmore 19606 Computerized Sewing Machine Logo
188 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
